Franklin Transmission
Started by just farming, February 24, 2018, 09:50:29 PM
just farming
I am getting very close to starting my 170 after a engine replacement. Its a 86 model 170. I've never ran one before and need some information. The previous owner removed the neutral safety switch and I'm uneasy starting a Detroit for the first time not knowing if I'm in neutral, forward or reverse. I don't have any kind of manual or anyway of knowing which lever is F-N-R and which is 1-4. It's a power shift transmission with 2 levers on the right side of the seat parallel to the machine.
Southside logger shared the shift patters on his but it's a newer machine and is different than mine. I also plan on installing a neutral safety switch when I find out where to put it.  Any help would be greatly appreciated.
Cat 311
JD 550G
ASV RC50
Mack Superliner RW613 Dump
Kubota M9000 4X4
Kubota L3430 4X4
Deutz-Fahr Agroplus 87 4X4
Southside
Can you access the underside of the shift levers?  If it's like mine it will be a series of neutral safety switches, that are activated by a plate with a series of milled out detents.  The NSS units feed power back to the solenoids on the transmission, it's a pain but with multi meter you can figure out what has power when, which should at least tell you where N is.  I did just send Charlie a text, I will text you if he gets back to me with anything useful.
White Oak Meadows
kiko
The fnr lever will have 3 detents and the gear selector lever 4.  Your transmission is a powershift , just does not have an electronic shifter.  I think I have some diagrams , I will try to dig them up.
just farming
A diagram would be great. I actually came to the same conclusion on the shift pattern this afternoon. I also discovered something else that concerned me. There is a 3/4 pipe nipple sticking up from the transmission open ended. I assume it is a vent but it should have some sort of a breather on I would think. Any sort of a wiring diagram would greatly appreciated as well.
Cat 311
JD 550G
ASV RC50
Kubota M9000 4X4
Kubota L3430 4X4
Southside
Was it the dipstick housing at one time?
White Oak Meadows
kiko
Hope this helps, I have much more info on this transmission.  P4-375 .
kiko
I could not find any info on the location of the neutral safety switch. There does not appear to be a port for it on the selector valve.  So it may have been located some where in the shifter cable assembly.
