Tree Volume & Value question
Started by Kirk_Allen, January 11, 2005, 03:36:42 PM
Kirk_Allen
I have a person in Indiana that has a walnut tree that we are trying to determine the volume of but the calculators only go to a 40: DIB.
This tree is 64" DIB and straight as an arrow for 65 feet where it hits its first branch.  Its another 10 feet after that branch before two mor branches.  It is a veneer grade log in my humble opinoin.
Does anyone have the formula for determing BF in such a tree.
Jeffs online one at http://www.timberbuyer.net/sawlogbf.htm or thru the toolbox icon over on the left will let you input bigger numbers and still get sensible answers.
I did try putting the tree we visited last week in... I got the right sort of answer, but had to scroll the result box to see it all. I dont think Jeff figured on logs scaling out over 100,000 bf  :D
Kirk_Allen
The online calculator you mention is for BF in a log which utilizes the small end of the log.
The "Tree" volume calculator, I assume, uses the DIB measurement and it only goes up to 40".  If I knew the actual formula I could input the appropriate number and figure the volume in the tree.
This is the calculator for Tree Volume
https://forestryforum.com/calcs/Board%20foot%20calculator.htm
ronwood
Kirk,
You can look at the Javacript on that link to see how it is calculated. On IE select View and Source and the JavaScript is shown. Might not be easy to go thru if you have never programed.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Ron Wenrich
The calculators don't use the small end of a log.  It is based on the amount of taper.  It doesn't figure a 2 log 30" tree is going to taper down to a 10" dib at the end of 2 logs.  It will taper to a set formula.
I didn't put in a top end to the dbh.  I had a stand that had several trees over 40" and my book ran out.  I then had to recreate those formulas.  The calculator does all that.
I guess if you can estimate the diameter at the top of the trunk, then divide the trunk into a series of tapering logs and work out the volume of each 16 foot section, you should get a good approximation?
The problem with a tree size calculater is... is the tree 50 ft tall or 150 ft tall.
You can make a generalisation based on average tree sizes in an area..... but for one exceptional tree, you really have to measure it dont you?
Used to like measuring those sitka spruce on the west coast to. Let's see, 95 inch dbh and 100 ft to the first branch, 250 ft to the top. There mine, all mine. ;D
