TK 1600 upgrade
Started by Tony, December 09, 2017, 11:15:28 AM
Tony
    Howdy all, I've got a TK 1600 of which I am well pleased.  As I get older so does my help; off bearer is 90, daughter and son are headed to college. This leaves just me. The mill didn't come with a log turner and the Logrite and I can only do so much.  I know it has been discussed here before, but would like ideas and thoughts on putting a hydraulic turner upgrade on the mill.
        Thanks  8) 8)
        Tony
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Kbeitz
Are you setup inside a building ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Tony
The building is the next upgrade. ::) ::)
                                                   Tony
Southside
I am not familiar with your mill, but if I were to put on a log turner I would only go with a chain turner, much faster and they are bi-directional.  I think that would be an easier fabrication / install too.
White Oak Meadows
DDW_OR
Quote from: Tony on December 09, 2017, 11:15:28 AM
        Thanks  8) 8)
        Tony
i have a TK-2000
have you called Timberking?
here is a link to useful sawmill mods
Quote from: Southside logger on December 09, 2017, 11:52:14 AM
I agree
ladylake
 I think a chain turner was a option on the 1600, should just be a bolt on and WELL worth it.  Steve
paul case
pc
WV Sawmiller
    I'd surely call TK and see if I could add their hydraulics or if they had a bigger hydraulic mill and took trade ins. The cost difference might be comparable or less than doing the upgrade yourself.
Gearbox
Put a winch on a rafter with a canthook hook . Simple fix if you are building anyway just center a 4x4 or 6x6 over the mill to pull on and bolt on a 2500 pound winch $50 on sale . I have rolled 40 inch White PInes with mine .
Kbeitz
Quote from: Gearbox on December 10, 2017, 09:53:20 AM
I agree 100%
ladylake
Nothing like a chain turner for turning logs fast.  Steve
DPatton
The newer models of the TK1600 come with a bidirectional chain turner option. I wouldn't have bought mine without it! I'd bet that the great staff at TK can set you up with everything you need. I guarantee you will wonder how you and your back ever got by without it!
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
Tony
     Called TK and ordered the log turner, looking forward to sawing with my "new mill" 8) 8)
                                                  Thanks,
        Tony
DPatton
That's great to hear Tony. I'd put my money on your gonna like it ALOT! Hope the guys at TK made it an easy and relatively painless process for you. Their customer service has always been great for me.
