2010 CRAWLER TRACKS 1963 model
Started by RoyBoy, December 04, 2017, 07:50:42 PM
RoyBoy
Need info on track repair on 2010 JD crawler ... 1963 model... pads are ok.. bushing are gone...  any ideas????
Thanks... royboy
RoyBoy
chet
coxy
just got pads an chains and sprockets for my 350 was 4 grand   the 2010 is that 5 roller if so 350 tracks will work same with a 1010 5 roller
chet
If this is for an early 2010, (before serial # 42000) then they are the same as used on 440 & 1010's.
Don_Papenburg
You should be able to get pins and bushings from Deere  Might have to make your own driving tool for removal and install . Could use a large truck kingpin driver with the right sized drifts.
RoyBoy
RoyBoy
