Author Topic: Got one of these  (Read 2015 times)
Offline drobertson
Re: Got one of these
« Reply #40 on: December 07, 2017, 06:20:08 pm »
Yes, and thanks, used file card for years, I just prefer brass brushes, not just for files, for sharp cutting edged tools of all sorts, they work much like a butcher's steel, but are more for clearing debris than straightening out cutting edges, without taking the edge off.
Offline knoxville
« Reply #41 on: December 08, 2017, 02:35:15 pm »
Does the Stihl 2-1 use special proprietary files, or can you use standard chain files?
you know butter but i know ham
Offline btulloh
« Reply #42 on: December 08, 2017, 03:44:55 pm »
File carders (the brush you're referring to) work well to clean the files when used on a regular basis but they don't sharpen the files.  Chainsaw files I do consider somewhat disposable, but the collection of good machinist files is too expensive to replace on a regular basis for me.  When a nice file stops cutting well, into the vinegar it goes.  Faster than trying to find a good replacement too.  Files are like chains as far in my opinion.  Sharper is better.
Same with drill bits.  Bit twist drill bits are expensive and besides that, you need it when you need it.  If it's lost it's edge I use my Drill Doctor.  (I'm sure KB can sharpen bits on a bench grinder, but I can't.)  Sharpening larger bits pays for the drill doctor real fast, plus I've always got a sharp bit for job.  (Sorry - off the subject, but then so is the acid thing.)
I'd like to try one of those Stihl jigs that started this thread, but then I'd need two or three different ones.  It's getting harder for my aging eyes to see what I'm doing with the file so I can keep the angle correct.
HM126
Offline Percy
  • Still got all muh fingers
« Reply #43 on: December 08, 2017, 05:07:16 pm »
Only guessing here but I think the round ones are standard. The raker file is  a fairly fat square one.
Its not the "years in your life" but the 'life in your years" that matters...Abe Lincoln
Offline hopm
« Reply #44 on: December 08, 2017, 05:32:03 pm »
Been sharpening by hand as long as I can remember. Butchered chains for years. Got the 2n1.....it works...does a great job....just nearly idiot proof
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #45 on: December 08, 2017, 05:51:49 pm »
I got the drill doctor the Darex and another one I can't remember the name of.
But I don't like wasting time setting them up unless I'm doing a 100 bits.
I have been hand grinding them since I was a kid. What I really don't like is
the new split point bits. They are great until they need sharpened then it's a
real pain. You have to thin the web after each sharpening . I even hand sharpen
my milling bits. It's not hard after you do a few 100. Try hand sharpening a drill
bit with a cut off wheel when your out on a job and there is no grinder around.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline moodnacreek
« Reply #46 on: December 09, 2017, 10:11:03 pm »
Although I file by eye and have for 52 years, a jig 0r machine that really works will beat the best man's eye. If your chainsaw can cut straight buried in wood, fast, undercut, bore cut  with little effort, it doesn't  matter how it was done. also if you can file by eye all you need is that file pocket on your work pants and 1 sharp file.
Offline TreeStandHunter
  • ISA Arborist from Michigan
« Reply #47 on: December 11, 2017, 03:46:46 pm »
I use this daily, Once you get the hang of it you'll be able to get your chains factory sharp no problem it is a great tool to have saves alot of time
Currently only have a Panther Mill 2, hoping to upgrade to a WM soon!
