Author Topic: Wood Mizer hydraulic loader cylinder Check valve replacement.  (Read 458 times)
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« on: December 03, 2017, 10:00:51 pm »
Hello,
  Last week I had a mill that was in need of some repairs. 6000 + hours and was next to abused. I did repair some of the issues. I called the customer and said we needed to work on the base line of the mill before we get to the other repairs he was requesting.
The owner carried the loading arm cylinders in, they were not attached to the mill.  :o Not a good sign.
Anyone ever see this? These fittings are on most every WM loading arm. If the hose would fail with a big log weight the check ball would seat in the fitting and prevent the loading arm from falling. Once in a while we see these fittings break off. The customers who are in freezing climates seem to let sawdust build up around the fittings and the mill moves and snap. There is a guard on the lower part of the arm but sometimes things happen.
The best way to remove the 1/4' tapered fitting.
Left hand drill bit. 7/16" winds them right out. I have also used a screwdriver flat head the same width, and a cold chisel.
Arrow points away from the cylinder. They should be replaced as a set because some may be rated at a different GPM.
Not sure if I should post this picture. The rear loading support was bent so bad that the lower pin would not reach. So I did the best I could do. Nothing pretty and I am not a welder.  :-[
Rushed the process a little.
This picture is another " if I just would of not turned it a little more"
I welded the tap in the hole and re drilled for the grease fitting on the log turner.
Front bed bolt was rusted tight, it came loose but not the way I was expecting.   More welding.
Hydraulic blade tension gauge. When you see oil inside time for a new gauge!
This is the blade guide arm motor to move it in and out. This is NOT the way it should be installed. The motor ears always point to the drive side , note the screw in this assembly. This is also not correct.
See anything wrong here? These bolts are not bent! The metal that the bolts go through are bent. It was hard to get the alignment in the picture.
Not the same mill but the same process was used to get everything back in alignment.
A little TLC and the mill was back to the customer on Friday.
Hope this helps.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Percy
  • Still got all muh fingers
Re: Wood Mizer hydraulic loader cylinder Check valve replacement.
« Reply #1 on: December 04, 2017, 12:04:51 am »
Oh my!! That mill musta went to a hammer fight......without a hammer.....
Its not the "years in your life" but the 'life in your years" that matters...Abe Lincoln
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: December 04, 2017, 08:06:59 am »
Now that was a project, Marty!   ;)
Good job!   thumbs-up
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider
Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
I LOVE MY SAWMILL
Online Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: December 04, 2017, 08:46:42 am »
I thought the Hydraulic blade tension gauge was oil filled from the factory ?
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline starmac
« Reply #4 on: December 04, 2017, 04:40:50 pm »
That was my thought when I saw the picture, but apparently they do not use oil filled gauges.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #5 on: December 04, 2017, 05:22:51 pm »
The gauge is filled with glycerin.  You can see a line of pink ATF fluid that Marty is referring to.
Offline starmac
« Reply #6 on: December 04, 2017, 05:25:13 pm »
Got it now.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: December 04, 2017, 06:48:47 pm »
I did that before,
When I lost a tire going 70 down I93.
I had to drill and tap. I did buy two, but just use the one.
All new hoses too.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #8 on: December 04, 2017, 07:37:04 pm »
I broke a velocity fuse because it got frozen in the junk, also. New set was same gpm (5 gpm), so I only replaced one and now have a spare.
I like the new hydraulic gauges, no more band tension settings to scare people away from burying the needle the way WM wants you to.  :)
Offline Chuck White
« Reply #9 on: December 04, 2017, 09:05:52 pm »
I still believe that too much band tension is hard on belts and bearings!
~Chuck~
I LOVE MY SAWMILL
    • My homepage
« Reply #10 on: December 04, 2017, 09:32:53 pm »
I've got almost 1,000 hours running at 3,000 psi with no trouble. Peter D has many more hours than me with no trouble. Its not really much more strain than running the 2,500 psi they used to recommend.
    • A&P Saw mill LLC
« Reply #11 on: December 04, 2017, 09:40:34 pm »
Ya 4500+ hrs. I do go through a lot of b57s, 6 a year.
Sawing since 1987
Offline Magicman
  • A "Traveling Man"
« Reply #12 on: December 04, 2017, 09:48:29 pm »
I have been running a "6 O'clock"  needle for well over 5 years and I know not how many hours.  I saw no increase in blade or belt usage, but I did see better sawing quality.
Regarding the velocity fuse; Bibbyman chucked one up in a lathe, reshaped the hex a bit and rethreaded so that the broken one fit again.  It's probably in the Useful Mods thread.
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline Chuck White
« Reply #13 on: December 05, 2017, 07:34:08 am »
 smiley_headscratch
Got me thinking!
~Chuck~
I LOVE MY SAWMILL
Online scully
  • Orange Mills Matter
« Reply #14 on: December 06, 2017, 12:09:19 am »
I have busted off 3 checks in the past . A couple were my own stupid fault . Easy enough fix . On the other hand I always wonder how some of the mils I see get so beat up . I can't  tolerate one single thing out of spec. on my mill .
A mans greatest tools are his heart ,hands and his imagination .
« Reply #15 on: December 06, 2017, 06:25:46 am »
Quote
This mill was purchased second hand. It was here longer than expected. I told the owner every time I went to work on it it made me sick.  >:(
His original request to up grade the Setworks to Accuset . I told him he needed more than a up grade. I think the mill will do what he wants. I have the base of the sawmill working well.
I hope others learn from the pictures.
M
