Rafter span table for eastern white pine
Started by bill m, December 02, 2017, 03:50:14 PM
bill m
I am getting ready to start framing another addition to my sugar house and would like to use white pine for the rafters. I can't find span tables for white pine so can anyone here help? The rafters will be full dimension 2X6 spaced 24 inches on center. The span is 7 feet with a 12 - 12 pitch, 1 inch pine boards with metal roofing. Will these be strong enough?
bill m
Don P
forum software must be kicking it out  ???
type in awc.org and you'll get to the main page, I think right column will say "calculators" or software, hit that and then the span calc is their first one.
bill m
Thanks Don. That's what I did and downloaded the charts. Not sure if I was reading it right but it looks like 2x6 pine will be ok.
drobertson
Not really sure of you all's snow load stuff that way,, but if 24" is a question,,then why not just go 16"?  it's over kill more than likely, but roofs that give way are bad too,,12-12, with a metal roof, that sounds like a good design to me, and on a short span, it should work, not sure of the knots you may be dealing with,  they seem to be the deal breaker even for SYP, very weak they can be at that tangent of the knot and wood,
I put the link in url tags and it made it work. I think the forum software has trouble justifying a link if it does not end in n extension. Just a guess
Chuck White
That's about what our sugarhouse is, only it is 6-12 pitch!
are you putting felt paper on the roof boards, under the steel?
Could save a lot of dripping!
bill m
Chuck White
47sawdust
I've used Vermont white pine a lot for rafters,roof pitch from 3/12 to 5/12.Strapped with rough sawn 2x4 and covered with 26 gauge metal.Felt or Triflex between the metal and the strapping.If you are nervous just oversize your rafters or space closer.On my wife's garage I sawed 3x8's and spaced them 24''©.It was overkill,but looks impressive.
I've never seen a rafter table for eastern pine,most folks wouldn't consider using it but if it is for your own use I'd do it,just use common sense.
Mick
