Author Topic: Added to my empire  (Read 862 times)
Offline ga jones
Added to my empire
« on: November 30, 2017, 04:24:37 pm »
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Offline ga jones
Re: Added to my empire
« Reply #1 on: November 30, 2017, 04:32:53 pm »
Let me know if the pictures are upside down
Offline ljohnsaw
« Reply #2 on: November 30, 2017, 04:35:15 pm »
No, just rotated to the right!
Nice toys!
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline coxy
« Reply #3 on: November 30, 2017, 04:49:50 pm »
good luck with it  8)      my buddy has the newer style   and its to fast in 2nd gear and the hydraulics  aren't  fast enough to keep up with it so you get the wash board effect  and 1st gear is like a turtle slow slow slow
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #4 on: November 30, 2017, 07:01:27 pm »
Nice, are you keeping your cable skidder ?
Offline PartTimeJack
« Reply #5 on: November 30, 2017, 07:11:14 pm »
You got some steep hills round your parts. ;D
A hickory stick, and a cherry twist for me.
Just a Farmer learnin to be a Jack.
Offline ga jones
« Reply #6 on: November 30, 2017, 07:20:58 pm »
Yes Iím keeping cable. I still feel it is faster. I can only get 2 big trees in the grapple. I can get 4 in the tray on the cable.its awesome for clear cuts though.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: November 30, 2017, 07:49:15 pm »
I have a d31P.
I highly advise that you pull the battery tray and look at the the two little levers with cam followers pushing against hydraulic spools.  Theyre at the very back on top and centered.  When you push a foot pedal the linkage rocks the rollertip into the spool which uncouples the drive first, push further and you engage the brake band.
These rollers and pins wear out and get way sloppy or flat spotted.  Sometimes the follower is tight or other times very loose based on how the parts are rotated.  You end up stabbing the pedal and the machine drives through the brakes because the slop prevents the hydraulic spool from being pushed in far enough to disengage power.  If the engine lugs with a turn or takes hard foot pressure to uncouple a track, thats your issue.  Replacing these simple pins and steel rollers will solve it.  Beware everything is metric .. But its easy to ream up to the next SAE size and just use american hardware.  The parts can be a pain to find oem.
Otherwise its been pretty good to me.
Another tip, theres a trans screener down low under your left heel, and a fuel screener in one of the banjo bolts.  Itll clog and kill power if you run the tank empty.
Offline ga jones
« Reply #8 on: December 01, 2017, 11:35:45 pm »
Thanks for tips on the screens. We already went through the issues with the pins and pedal linkage. It was all siezed when I got it.👍
Offline mike_belben
  • Pulp Friction
« Reply #9 on: December 02, 2017, 09:57:18 am »
Did you have to pull the top covers to change that stuff out?  If so, did you notice were there bushings or parent metal where the shafts passed through the cover?  Mine are all slop and i havent sourced the parts or got my shop relocated/set up to make replacements.
Offline ga jones
« Reply #10 on: December 04, 2017, 09:06:37 am »
Mine was seized from sitting. Lubrication and working them got everything back in check.
