Author Topic: Wheel Harvesters  (Read 2193 times)
Offline Skeans1
Re: Wheel Harvesters
« Reply #40 on: December 04, 2017, 08:53:37 pm »
I think forests would benefit a lot from harvester and forwarder rentals.  Would take a lot of pressure off the mechanized crew to cut cut cut no matter what what what.
Problem is out here would be the stuff is mainly used for thinning which honestly isn't something everyone can do or make it profitable. The winch systems is what I was told they were going to rent, could you imagine what a 500k+ machine would look like if you let just any crew rent it?
Offline mike_belben
  • Pulp Friction
« Reply #41 on: December 04, 2017, 09:36:54 pm »
Oh i didnt say the lease corporation would survive long.  Im sayin the forest might
 :D
Offline 1270d
« Reply #42 on: December 04, 2017, 10:21:15 pm »
That would be slick to rent/lease the tether system.  Better than shelling out a couple hundred grand for a setup if you don't use it much
Offline Skeans1
« Reply #43 on: December 04, 2017, 11:05:32 pm »
We were looking at some of our personal thinning ground that's due we could use the system there's no way to get to the bottom otherwise, plus it's only one machine for both yarding and cutting which makes more sense to me.
Offline Riwaka
« Reply #44 on: December 06, 2017, 07:28:33 pm »
John Deere g series smaller wheel harvester 1070G (4 and 6 wheel ) 1170G 6 and 8 wheel.
Offline Skeans1
« Reply #45 on: December 07, 2017, 12:56:57 am »
Thank you, if we go Deere it would most likely be a 1270 one reason is the capacity of the head they can handle for the wood we see here in some of the thinning we do. The 1170 far as I know hasn't been sold out here before one reason could be the crane not being strong enough on the slopes we see or for the wood we see out here for weight.
Offline Riwaka
« Reply #46 on: December 10, 2017, 02:31:24 pm »
Logset from Finland, heads look fairly robust, power to weight ratio could be better than John Deere. Logset standard with Mesera crane.
https://www.logset.com/harvesters/logset-8h-gt
log set  8h gt  (300hp Agco engine?)
john deere 1470e h290 haas winch(mesera 280 crane)
