Tree ID
Started by EricHanley, November 22, 2017, 10:55:34 PM
EricHanley
My neighbor has a down tree and I want to make a workbench. What kind of tree is this and is it suitable for a workbench?
rjwoelk
Welcome to the form.
Hard to tell perhaps the fellows from downunder can see it rightside up. :D
ToddsPoint
Looks like it might be silver maple.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
DPatton
I think ToddsPoint hit the nail on the head.
D & S Sawmill Services
BigBurOak
Either Silver or Red Maple, both of which are commonly referred to as soft maple;(700lb and 950lb Janka hardness respectively). It should be fine to use as a work bench, considering that Black Cherry has the same hardness as Red Maple :laugh: Even Silver Maple I would use, although to tell the truth I wood use almost any wood besides Balsa :D
Who needs a gym if you got a woodpile?
Ron Scott
Yes, to silver maple.
~Ron
low_48
8/4 soft maple is really reasonable. You could buy some and build tomorrow. It will take months to get that log into useable lumber if you are building a workbench to make furniture on. If you are just building something to work on your lawn mower in the garage, then you can go for it. Looks like silver maple to me, and it's not nearly as hard as cherry. Looks like rot in the center of the butt flare too.
