JD 110 Hyd Pump crashed
Started by Qweaver, November 08, 2017, 01:16:48 PM
Qweaver
Front loader quit working and big grating noise started coming from the front of the tractor.  I shut it down immediately and I'm guessing the Hyd pump is gone.  I don't even know where it's located.  I replaced one on my old Ford and it was easy.   Any hints where I should start looking?  I guess it's time to buy a manual. There go the profits from the $1000 saw job I just finished.
Quinton
I had a similar incident with my Cat backhoe. It turned out to be the coupling between the engine and the pump. The screw that clamps the coupling around the shaft had come loose and it ground all the splines out of the coupling.
Dave Shepard
You've mentored having problems with the coupling before on this tractor. Isn't the pump run off the front of the crank?
Qweaver
Yeah DanG, I had that happen on my old Ford backhoe too.  I hope it is something like that this time also.  But I will not be able to work on it until Monday.  My Kubota  will see me thru until then but I can't lift the big logs with it.  I wish I had a workshop manual.  It might save me a lot of time if I knew exactly how to do it.
Quinton
Qweaver
Quote from: Dave Shepard on November 08, 2017, 03:49:59 PM
How in the world  did you remember that Dave.  I had forgotten it.   This is the second time.  It is a sintered splined hub  and probably designed as the weak spot to fail before the pump splines.  $76  and had to be ordered.  I sure hope the pump splines are OK.  I remember that it was not an easy job to replace it.
Qweaver
My diesel mechanic cousin showed me the easy way to do this repair and it went very quick and well.  I put a spare on the shelf just in case it happens again.
