Wheel Rim Size for Woodmizer LT40HD
Started by Mountain_d, October 24, 2017, 09:01:37 AM
Mountain_d
I need to move a 1995 Woodmizer LT40HD. The mill is about 6 hours away from me and I am not able to get the size info for the rims. I want to take a few spare wheels along assuming the tires are done. Can someone tell me the rim size, number of wheel studs, centre hole diameter and distance centre to centre between to adjacent wheel studs and wheel stud diameter ( if other than a standard wheel bolt size)? Also the tire size. Thanks a bunch. Mountain D.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
PC-Urban-Sawyer
I think you should call Woodmizer support. If you happen to already have the serial number they can give you all sorts of info and even if you don't they should be able to give you the wheel/tire info. You'll want to register ownership with them anyway to get all the additional support they will provide. You need to know that their support continues, even if the original warranty period has expired.
terrifictimbersllc
I second this suggestion.  You can count on them to for help. Press the buttons for tech support and explain your problem.
Chuck White
I have a 1995 LT40HD also!
The Center Hole in the wheel rim is 3¼"!
The Stud Spacing is 2¾" ctr-to-ctr!
There are 5 studs!
Tire Size:  ST205/75/14
loganworks2
I would plan on mounting new tires before transporting the mill. Bad things happen fast when trusting tires that old.
Chuck White
I'm not sure, but I think that Wood-Mizer has tires mounted on rims in their store!
Mountain_d
Thanks for the info everyone. Good suggestions. Mountain D.
pineywoods
X2 on the new tires. Couple weeks ago, I did a repair job on a "new to him" wm lt40 mill. On the way home with his new purchase, tire on the operator side shredded and tore up the plastic conduit that carries all the wiring out the back of the control head. In the travel position, that cable bundle is right over the tire...
Klicker
Check and grease the wheelbearings. Don't ask why.
2006 LT 40 HD
