Author Topic: Blade tension  (Read 995 times)
Offline Coltbodi
  • Sure, I can fix that
Blade tension
« on: October 12, 2017, 03:55:55 pm »
I just swopped my Timberking 1600 over to 1&1/2" blades. I threw a big pine on the mill this morning to try out my new blades and roller guides. It cut great on the 1st log, but on the second log I got a huge dive, about an inch and a half. I cut 5/8" boards out of the 1st log, so I made lots of cuts, the blade being brand new and sharp is probably the only reason I got good cuts on the 1st log. I checked all my guides and made sure everything was level and square after I got that big dive. Eveyrthing was still where it needed to be. Then I pushed the blade down and it was really easy to shove it down from the roller guides, that's when it hit me that these bigger blades where going to need more pressure on them to get them to the correct tension than the 1&1/4" blades did.  I cranked down on the tensioner, bottoming out the spring, which wasn't but a couple turns more than where the mark was for the smaller blades. I finished cutting that log and cut up another one with out any problems. My question is how do you guys get your blade tension right when you change blades? I am thinking that to much tension is not good for the bearings in the drive wheels. Is the only way to get it dialed in correctly to buy a band blade tensionmeter? The one on cooks site is $240! I'd hate to spend all that money for something I only use once.
If I can't fix it, I don't want it.
Timberking 1600 with lots of mods, a 65hp mahindra with a front end loader, a welding shop, and sugarcane mill from 1890 for making syrup
Offline ladylake
Re: Blade tension
« Reply #1 on: October 12, 2017, 07:12:29 pm »
 Easy to push down from the roller guides?  Do you have at least 1/4" down pressure. Is the blade level with the bunks before adding down pressure?. If the movable guide is like the TK 2000 do you have a plastic shim between the u shaped piece and the frame to keep the guide arm from lifting when extended.  Steve
Online Kbeitz
  • Never enough time...
    • My Hobbies
Re: Blade tension
« Reply #2 on: October 12, 2017, 07:18:03 pm »
You can clamp on a 6" dial caliper to get your reading...
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline Coltbodi
Re: Blade tension
« Reply #3 on: October 12, 2017, 07:19:19 pm »
yes I have 1/4" down pressure, the blade is level to the bunks, and there is no shim on the slider arm (I don't think the 1600 has that), but its not moving. The blade was just easy to push down from the roller guides because there wasn't enough tension on it. The tension is different from the 1&1/4" & 1& 1/2" blades, I just need to get the tensioner dialed in.
Offline Coltbodi
Re: Blade tension
« Reply #4 on: October 12, 2017, 07:21:48 pm »
So you open the caliber up a couple inches, clamp the arms down to the blade and take a reading, then tension it?
Offline ladylake
Re: Blade tension
« Reply #5 on: October 12, 2017, 07:38:44 pm »
 I'd be checking the down pressure again, granted a 1 1/2 blade need more tension but even tensioned up to where the 1 1/4 blade was the blade should not be easy to push down from the guide rollers. On the TK 2000 the movable guide arm wasn't sturdy enough and need a plastic shim above it to keep the arm level when extended. Also the blade has to be level with the deck before adding down pressure ,if not you will end up with more down pressure on one side or the other to keep it level with the deck . You shouldn't have had any problems cutting straight with a 1/1/4 band if everything was adjusted right.  Also what brand of blades are you running, I tried one brand and sent them back as there was no way to cut straight with them.   Steve
Offline Coltbodi
Re: Blade tension
« Reply #6 on: October 12, 2017, 07:56:05 pm »
Yes, the blade was level before. and the down pressure hasn't changed. When I say easy I don't mean that a paper clip could push it down, its just easier than it should have been.
Online Kbeitz
    • My Hobbies
Re: Blade tension
« Reply #7 on: October 12, 2017, 07:58:07 pm »
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline Coltbodi
Re: Blade tension
« Reply #8 on: October 12, 2017, 08:52:39 pm »
I saw a few videos on youtube of them doing it with a caliper. Ill give it a try tomorrow and see what I come up with. Thanks for the tip
Offline drobertson
Re: Blade tension
« Reply #9 on: October 12, 2017, 09:29:35 pm »
If it were me,, I would call TK, but in the meanwhile I would also check the blade lube, (heat) it can and will cause so many issues,,bigger means more, as in tension, so if the mill was designed for a 1-1/4" band, then you may be at the max?  You may be able to cheat it,, with a spacer or the like,, a call to techs would be my move.
Offline Coltbodi
Re: Blade tension
« Reply #10 on: October 12, 2017, 09:46:08 pm »
The blade I staying cool, no issue there. And calling TK is out of the question. I know it's the blade tension. That was easy enough to figure out. I just wanted to know if anyone knew of a way to get it right without the $240 tensionmeter.
Offline ladylake
Re: Blade tension
« Reply #11 on: October 13, 2017, 10:39:36 am »
 I checked my mill this morning with the blade tensioned normal, yellow spring at 1 7/8" it takes quite a bit of pressure to push the blade off the roller guides. Steve
Offline AnthonyW
  • Wannabe hobby sawyer
Re: Blade tension
« Reply #12 on: October 13, 2017, 11:37:38 am »
If you have the blade at tensioner at full adjustment and the blade is still loose, could the blade be 1/2 or an an inch longer? Have you tried another blade? (I know that's the standard question to ask, but...) I recently received some blades for my vertical bandsaw that I couldn't tension well, then compared and found out they were an inch too long. So there is not enough travel on my vertical bandsaw to tension a 133.5" blade on a 132.5" 'saw'. Can't image the same thing isn't true for the bandmills (though the length discrepancy may need to be larger)
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Offline Pabene
Re: Blade tension
« Reply #13 on: October 13, 2017, 01:46:52 pm »
Here is a cheap, safe and accurate way to check the tension in band saw blade and the background. I have learned the tension for blades can be 7-8% of the force when it breaks. As the steel in the blades body is similar to each other will such tension prolongs the blade about 1/1000 of the length you are checking. That means a narrow thin blade needs less force to be stretched. A wider and thicker blade needs a lot more force from the saw tension system. Some band saws are to weak and canít resist the force a wider blade needs without to be deformed.
Open the doors so you can see a long free part of the blade, the longer the better. The upper part of the blade can be the best part for this check.
Clamp two flat rods/iron to the blade, one clamp close to the left wheel and one clamp close to the right wheel. Leave an open distance between the rods ends about 10 Ė 20 mm. Measure the distance between the clamps. (Say it can be 1000 mm)
Take a caliper and measure the distance between the inner ends of the rods.
Now, start to crank up the tension. Take measurements until the distance between the inner ends is increased with 1 mm.
This is the same method as described with just the caliper but you will have a lot better accuracy this way.
Most of the expensive blade tension meters works this way and has a green sector for recommended tension.
Offline drobertson
Re: Blade tension
« Reply #14 on: October 13, 2017, 02:53:29 pm »
I was not sure what color spring TK uses, so the reason for the call,, each spring applies (x) amount of pressure for a given distance of compression.  Not knowing the allowable load allowed on your mills bearings, or anything else for that matter concerning your specific mill my comments are and have no valid point.  It really sounds like you have a learning curve to take care of, and more than this know the limits of the mill you have,, even 6" band, high production mills have limits,, dives occur more times than not from to much feed, and or dull blades, and poor alignment.  It sounds like according to Steve, Ladylake,  a seasoned TK mill owner, would be the one to ask, if the engineers cant help.
Offline Coltbodi
Re: Blade tension
« Reply #15 on: October 13, 2017, 06:25:18 pm »
All is well now. I used the caliper method and got the tension to 18,500 psi. No more dives.
Offline ladylake
Re: Blade tension
« Reply #16 on: October 13, 2017, 07:01:33 pm »
 Hopefully you don't have that yellow spring bottomed out to get that tension, no way I'd run my mill like that as it would be too hard on the bearings and blade.  Steve
Offline drobertson
Re: Blade tension
« Reply #17 on: October 13, 2017, 07:05:28 pm »
sounds like you slowed down a bit,, glad to hear,
Offline Coltbodi
Re: Blade tension
« Reply #18 on: October 13, 2017, 07:09:18 pm »
It isn't bottomed out.
Offline Coltbodi
Re: Blade tension
« Reply #19 on: October 13, 2017, 07:12:42 pm »
I'm still cutting at pretty much the same speed, I just go by the sound of the motor with my speed, which differs from log to log depending on knots and such. I am defiantly enjoying these 1&1/2" blades. I cut some 1x8's and 1x10's at the same time out of a cant today and it cut great all the way down. Ended up with a stack of (20) 1x10's and (20) 1x8's on the mill by the time I made the last pass thru.
