Author Topic: Top Saw  (Read 1089 times)
Offline gsturdivant
Top Saw
« on: October 09, 2017, 08:01:09 pm »
Need any suggestions or information on building a top saw on circle mill
Offline sealark37
Re: Top Saw
« Reply #1 on: October 09, 2017, 08:15:48 pm »
The one top saw that I have seen in operation was mounted on a very substantial husk frame that supported both the main and top mandrels.     Regards, Clark
Offline irvi00
Re: Top Saw
« Reply #2 on: October 09, 2017, 08:37:49 pm »
You could check out Hurdle mills. Maybe they have some pics. A top saw would involve a lot of work.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: Top Saw
« Reply #3 on: October 09, 2017, 08:59:25 pm »
 welcome    gsturdivant
Mandrel or electric motor drive on a 4 post stand,
The big circle saw builders have them
a simple Google search will uncover them
Also
http://www.forestryforum.com/board/index.php?topic=1866.0
D
Offline bandmiller2
Re: Top Saw
« Reply #4 on: October 10, 2017, 07:58:51 am »
In principal the topsaw is a simple device but in practice a lot of fiddling. I had one and sold it. If you must I would run a smallish saw with an electric motor on a heavy duty steel frame. Bit width must match headsaw. Frank C.
Offline Don P
    • Calculator Index
Re: Top Saw
« Reply #5 on: October 10, 2017, 08:15:43 am »
great minds and all that, this is another thread from Mitch's build;
http://www.forestryforum.com/board/index.php/topic,2238.msg28510.html#msg28510
Offline longtime lurker
Re: Top Saw
« Reply #6 on: October 10, 2017, 09:01:11 am »
A breakdown rig without a top saw would be unusual here. They aren't real complex: get your spacing right so the bottom saw is clear before the top cuts through, overengineer everything because the weight of saw (and the logs that need it) requires it, make sure your feed can handle the slower pace. .. then change your breakdown pattern to use it as sparingly as possible. Nothing technical about it.
Offline Ron Wenrich
Re: Top Saw
« Reply #7 on: October 10, 2017, 11:26:50 am »
I sawed a lot of big logs without a top saw.  The vertical edger helped quite a bit on big logs.  Never had a need to chainsaw the cut.  You just have to think your breakdown a little differently when you saw a big log.
Offline gsturdivant
Re: Top Saw
« Reply #8 on: October 10, 2017, 12:41:13 pm »
Thanks for all of replys
Offline Andries
  • LT30G24
Re: Top Saw
« Reply #9 on: October 10, 2017, 01:49:38 pm »
Some pictures (worth a thousand words?) of a top saw near where I live.
Almost any kid will run a chore for you - if asked an hour before bedtime . . . .
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
Re: Top Saw
« Reply #10 on: October 10, 2017, 02:07:34 pm »
As Andries says.  :) Here are some pics for you i found on my computer that I took quite a few years ago at the West Branch engine show.
Offline Andries
  • LT30G24
Re: Top Saw
« Reply #11 on: October 10, 2017, 02:18:18 pm »
Here's a photo of a line belt driven top saw.
Maybe some good ideas to pick over before you start your build.
Online JRWoodchuck
Re: Top Saw
« Reply #12 on: October 12, 2017, 01:32:41 pm »
Those are some of the most terrifyingly awesome things I have seen in awhile!
Home built bandsaw mill still trying find the owners manual!
Online Kbeitz
  • Never enough time...
    • My Hobbies
Re: Top Saw
« Reply #13 on: October 12, 2017, 03:01:23 pm »
Yea... Like what way do I run when something goes wrong?
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Online Crusarius
  • Lost in....
    • RockModified.com
Re: Top Saw
« Reply #14 on: October 12, 2017, 03:44:35 pm »
too late at that point.
I knew what I thought I meant.
Offline BUGGUTZ
  • !wen m'I
Re: Top Saw
« Reply #15 on: October 13, 2017, 08:49:40 pm »
Hey Jeff, does that West Branch show still happen? I would love to see that big bugger run!
Everyone has to be somewhere.
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Top Saw
« Reply #16 on: October 13, 2017, 10:13:58 pm »
Yea, but I'd have no idea if the big saw would be there. It would come in from Missouri.
Offline thecfarm
Re: Top Saw
« Reply #17 on: October 14, 2017, 05:34:10 am »
Now that's a mill!!!! That has my attention.
