jd350b
Started by coxy, October 07, 2017, 06:10:58 PM
coxy
does any one know of a way to get the bolt loose that tightens the brake band up with out pulling the final drive off (cant believe it seized up in 6 months)  I don't want to spray anything in there afraid it will make the clutches slip if it gets on them I don't know how much pressure to put on the bolt before it brakes if I didn't need to use it now I would just put a piece of pipe on the ratchet and go but I know if I do that now it will brake and don't need that at this point
luvmexfood
Quote from: coxy on October 07, 2017, 06:10:58 PM
Can't help you but would love to have a good 350 with 3 point hitch to bushog with.
rdobb13
If only it was a 450, just spent a week on one.  Not sure how close they are to each other.  Is the clutch adjustment access a small plate under the seat?
coxy
rdobb13
I broke the tanks loose from the bottom and left all the lines hooked up.  Took a come a long and raised them up, took the whole top plate off.
It gives you enough room to get to the brake band.   Take the pipe plug out of the side and you can pull the shaft that holds the band in place.
coxy
a 350 is different you have to change the steering clutches and brake by taking the final drive off its a pita on the 350 and 350b     the 350c isn't bad there is no seal to mess with the b has a seal to keep the oil out of the clutches   you can adjust the brake through the top cover its maybe 6x6 with 4 bolts
bushmechanic
You only got two choices other than removing it, the first being heat and the second being pounding with a hammer in hopes of swelling up the part and loosing the threaded part.
coxy
Quote from: bushmechanic on October 10, 2017, 05:54:41 PM
what about the 3rd choice    sell it  :D     I was thinking about hitting it but its a pita to get a good swing on it
snowstorm
if there is any way to get at it heat it. torch    heat gun sometimes if your lucky will work. or the bolt heating coil. i dont have one was told how they work by someone that dose. he said it was great. it heats only the bolt or nut
pineywoods
First, try some blue creeper. That stuff works wonders...
coxy
Quote from: snowstorm on October 11, 2017, 06:06:39 AM
for got about them
