BRUTE FORCE Authorized Dealer
Author Topic: LT 40 woodmizer drive belt  (Read 224 times)
Offline armechanic
« on: October 04, 2017, 10:24:51 am »
I ordered a new drive belt for my 1988 LT 40, I am about to run out of adjustment and can't get it loose enough to break over.  The belt is the new double belt from Woodmizer  part # P09555-2. I am wondering if it will stretch, It also looks like it may rub on the top. I have the top nut about half on the shaft.  Thanks for ant ideas.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline Chuck White
  • Sawing Mobile since 2005
Re: LT 40 woodmizer drive belt
« Reply #1 on: October 12, 2017, 09:53:24 am »
Wood-Mizer has a new turnbuckle available which should provide more adjustment for you!
Over time, the belt will stretch "some", and may need adjustment at 50 hour intervals!
When adjusting, adjust to 7/16" deflection with 14 pounds of pressure!
Adjust the rod/bar the is on the back of the engine and under the belt so that it is 1/8" below the drive belt, with the belt tensioned!
This info was provided to me by Wood-Mizer, Indy!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider
Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline armechanic
« Reply #2 on: October 20, 2017, 09:58:12 am »
Update ,  Not good I finally got enough adjustment so I could work the clutch ?  Now when I declutch it squeals and smokes. I am cutting semi dry hardwood (cherry & oak) using 4 degree doublehard WM blades and they dip & dive on every knot, blade tension is about 2200-2300 lbs.  I  will either go back to using two separate belts or make a longer adjustment bolt.  I think the reason for the dipping on knots maybe I changed the rpm's (lower) when I adjusted the drive belt. So I will readjust the linkage to the carb.
Offline Chuck White
« Reply #3 on: October 20, 2017, 12:42:28 pm »
Sounds like a call to Wood-Mizer Technical Service is in order!
They should be able to handle your situation over the phone, in a few minutes!
~Chuck~
I LOVE MY SAWMILL
Offline armechanic
« Reply #4 on: October 21, 2017, 11:16:23 am »
I think it may be time to talk to WM too.  I installed a larger pulley on the engine along with the tighter belts on the blade wheels in an upgrade a few years ago, I am wondering if that may be the problem.  The belt just seems to short.  Anyway I will post results when a "fix" is found.
