Author Topic: Tips for disassembly of timber frame?  (Read 422 times)
Offline terrifictimbersllc
    • Terrific Timbers LLC
« on: September 09, 2017, 04:56:16 pm »
I am about to try to take apart a timber frame treehouse, hoping to save the frame.  Members are hemlock which were pegged with red and white oak pegs, tightly draw-bored.  The pegs were inside (very) dry,  and the frame was probably 15-20% MC when the frame was assembled.
I am planning to try to knock the pins out with cylindrical punches made out of steel round stock, but have no idea whether this will work yet.
Am wondering whether anyone knows of  tricks to timber frame disassembly. Maybe  center of the pegs for example or drilling out the pegs and heating them somehow to shrink them to make them easier to get out.   Advice welcome.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Don P
    • Calculator Index
Re: Tips for disassembly of timber frame?
« Reply #1 on: September 09, 2017, 05:29:15 pm »
I'd try drilling the center of the pegs out with a long 5/8" brad point bit and then punching them out. A few taps each way to get them moving. If they are extended put a set of vise grips on them and twist a little as you go. If they are stuck use a long 1/4" chisel and collapse them into the drilled hole.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: September 09, 2017, 05:43:15 pm »
3/16" pilot hole and sink a 6" Headlok, or GRK RSS, and a long pry bar. A slide hammer with a hook to catch the screw head is even better.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #3 on: September 09, 2017, 10:39:44 pm »
When you do this, sometimes the peg may split. If it does put a hose clamp around it to hold it tight or together around the screw.
Also, some people put a small cone shape into the end of their "push pin" so that the end of the peg being pushed can be centered on the push pin. You have to be careful that the push pin doesn't go beside the old peg and get wedged in there.
Jim Rogers
« Reply #4 on: November 07, 2017, 11:28:40 am »
I pulled two 6" pegs quite easily this morning.
One peg was 3/4" and the other 1" diameter.  First I drilled a 3/16" hole all the way through the peg.  Then I screwed in, most of the way, a 5/16" GRK-RSS screw.  I used a 4" screw for the 3/4 peg,  and a 5-1/8" one for the 1" peg.  I put a nut under the head of the screw.  I didn't insert the screw all the way just to the end of the main threads.
With a 48" wrecking bar from Harbor Freight ($25) each pin came out quite easily.  The only trick was holding up boards of increasing thickness to pry against, to avoid bending the screw.  The nut actually helped a little with the spacing, I could pull on the nut or not.
I now feel confident I can take the frame apart efficiently and without damage .  Thank you all for your replies and Dave for this excellent tip.
Offline DPatton
« Reply #5 on: November 07, 2017, 07:13:44 pm »
That's a great photo demonstration of how you did your peg removal. Thanks for sharing.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #6 on: November 07, 2017, 09:56:17 pm »
Why on earth would you take down a timber frame treehouse???? :snowball:
« Reply #7 on: November 08, 2017, 06:35:19 am »
A time to build, a time to take down.
It's going to live somewhere else.
