Cure for my Onan.
Started by Jeff, August 27, 2017, 01:44:03 PM
Peter Drouin
You'll be sawing in no time.
A&P saw Mill LLC.
License NH softwood grader.
Chuck, what specs are you using for belt tension?  I set mine at 12lbs at 1/2" deflecion. Seems like maybe a little to much belt bounce on the bottom side.
Chuck White
Jeff, I'm setting mine at 7/16" at 10 lb.
The new belt is longer than the original, so I think it "could" be a little tighter!
My drive belt is running quite smoothly, hardly any flop!
The bounce/flop will probably change when you put a load (sawing) on it.
I sawed a cedar log last night, and it sawed fine. I never even thought about watching the belts when I was sawing.  DOH!
Chuck White
Way to go Jeff!     ;)   thumbs-up     8)
Percy
So now Jeff is sawing lumber for the U.S.S. Kittyhawk??   ???
Percy
Quote from: Magicman on September 17, 2017, 09:23:13 PM
Man!! You have good eyes. I didn't even see that. It's a generic program for fake newspapers. 🤓🤓
sparks
Jeff, 7/16" at 14lbs. You'll burn up the belt with less and your blade will wander.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
It sure is good to have my sawmill running again and running well! Tammy and I used it to saw out a 20 foot extension to our Polebarn privacy fence. The cedar cut like butter with the rusted blade that had been on the mill since last year. :) it really did feel good to be sawing again. 8)
The results of that "feel good" feeling looks good too.   8)
