Author Topic: Sawing Tapered Posts  (Read 1724 times)
Offline highleadtimber16
  • Learning Everyday
« on: August 05, 2017, 01:15:43 am »
I've been asked to saw tapered 12x12 posts, fir or cedar. 12x12 down to 9x9. Wondering what the most efficient and accurate way to do this is? Use a wedge or the toe board? I've done beams with an angled top but never tapered posts.  :)
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Sawing Tapered Posts
« Reply #1 on: August 05, 2017, 05:59:37 am »
For reproducibility I'd use a block to elevate one end.  I'd make a diagram for each cut.  I guess there are only really 2 cuts to plan out.   Also pay attention to how you keep  it square.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline btulloh
« Reply #2 on: August 05, 2017, 08:45:54 am »
It goes without saying, but just in case I'll say it:  Cuts 3 and 4 need shims twice the height as the shims for cuts 1 and 2.
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #3 on: August 05, 2017, 01:02:30 pm »
Plus kerf ;D
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #4 on: August 05, 2017, 06:52:59 pm »
Minus wane
Boy, back in my day..
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #5 on: August 05, 2017, 08:08:53 pm »
Who's Wane and why does he get left out?  ???
Online killamplanes
  • one man band
« Reply #6 on: August 05, 2017, 08:42:01 pm »
 :D :D :D
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Offline 4x4American
    • Website Link
« Reply #7 on: August 05, 2017, 09:32:46 pm »
He acted up and now is in the woodshed.  A somber day.
Offline LeeB
« Reply #8 on: August 06, 2017, 12:24:58 pm »
Is the woodshed where you go to somber up when you had too much purple drank?
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346, 372 and 562XP's. Stihl MS180 and MS361, 1998 and 2006 3/4 Ton and 2005 1 ton Dodge 5.9 Cummins 4x4's, 1989 Dodge D100 w/ 318, and a 1966 Chevy C60 w/ dump bed.
Offline 69bronco
« Reply #9 on: August 06, 2017, 03:26:30 pm »
Never had much use for Wayne anyhow :)
Offline btulloh
« Reply #10 on: August 06, 2017, 03:32:30 pm »
It never takes too long for a serious topic to end up at the comedy club.   :D :D
HM126
Offline rasman57
  • Location: Manistee National Forest Pine River Michigan and Home in Illinois
  • When you come to a fork in the road...take it.
« Reply #11 on: August 06, 2017, 04:39:09 pm »
So Wayne....the guy in the sombero started a Comedy Club in his Woodshed and serves Purple Drank.  I was having trouble keeping up but now understand.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #12 on: August 06, 2017, 10:20:55 pm »
. . . . . but I walk away to the woodshed shaking my head.
1992 LT40HD
The winds of change are blowing at hurricane force and I don't like it but good shall come even though I see not how.
Offline John S
« Reply #13 on: August 07, 2017, 06:59:54 am »
Wane is in his own World!
LT40HDG28
Offline dsgsr
« Reply #14 on: August 07, 2017, 05:37:56 pm »
All joking aside Folks, I've never done this. I'm not to smart when it comes to milling so how would this be done. I would envision marking out the ends of the log and shimming to get that cut.  But how do you know it's going to make the cut?
I'm pretty good at making things come out different than intended:)
David
Northlander band mill
Kubota M59 TLB
JD 5085M
Takeuchi TB175 Excavator
'08 Ford 550 dump
Offline Magicman
  • A "Traveling Man"
« Reply #15 on: August 07, 2017, 06:14:17 pm »
Look at your starting height.  Raise the head and travel to the other end and lower the head to the starting height.  That will show you what the finished cut will look like.
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline grouch
  • I'm recyclable!
« Reply #16 on: August 07, 2017, 06:52:42 pm »
Hope I'm not screwing this up in my head.  ;D
Get the pith level then prop the small end up 1-1/2 more inches (12 - 9) / 2 = 1.5. Cut 6 inches above the pith on the big end.
Rotate 90 and repeat.
Rotate 90 and prop the small end up 3 inches; cut for 12 inches at the big end.
Make sense?
Find something to do that interests you.
Offline btulloh
« Reply #17 on: August 07, 2017, 07:24:54 pm »
What Grouch and Magicman said.  If you're tapering from end to end, Be sure the end that stays on the bunk is the pivot point.  If your bunk supporting the lower end is not at the end of the log, you'll get a taper between the raised end and the point where the log is sitting on the bunk.  The rest of the log, from the bunk to the far end will be straight.  You may need to support the far end of the log with a board between two bunks to make it work.  If so, add the thickness of the board to the shims you're raising small end with.
To be safe, I'd cut one for practice just to get the feel of it.  It's a lot like cutting tapers on table legs on the table saw, but with this the saw is moving and not the work.
HM126
Offline btulloh
« Reply #18 on: August 07, 2017, 07:25:52 pm »
Another thing that probably goes without saying:  Make a regular cant first and then taper it.
HM126
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #19 on: August 07, 2017, 07:41:10 pm »
I have another way. I made a lathe attachment for my mill.
I just put the log on the lathe and raise the tailstock.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
