Author Topic: Eastern Larch drying and use  (Read 512 times)
Offline Baron
« on: July 31, 2017, 10:55:41 am »
I Would like to use Larch (tamarack) for my new deck. I have never worked with it before and need to ask advice. Is it sappy enough that it needs to be kiln dried. I only have a Solar Kiln which is great for hardwood but not for fixing resin.
Can I use it green and lay it board to board and count on natural shrinkage to open the proper sized gaps?
I am fixing to use it rough sawn but with one surface planed. Will that be nice on bare feet? will I regret not fixing the resin in a commercial kiln?
Baron
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
Re: Eastern Larch drying and use
« Reply #1 on: August 01, 2017, 08:54:45 am »
Tamarack does have a lot of pitch, maybe why it lasts longer. I would be more concerned about splinters if using for a deck. Just my 2cents
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline Baron
« Reply #2 on: August 04, 2017, 09:36:14 am »
Hey Bronco, So would you lay it green and let it dry for a year and stain or would you make sure you kiln dry it prior to use? is your fear of splinters based on life experience with walking on eastern larch?
Offline 69bronco
« Reply #3 on: August 05, 2017, 08:03:23 am »
My son's buddy did a 20 acre clear cut of tamarack. They have a large sawmill/kiln operation and sawed it all. Kiln dried, pitch set it was splintery. Son tried to use some on picnic tables, you wanted to make sure an not slide your butt! Other than that I have only used it for timbers, my tamarack is almost gone . Not more than half a dozen trees left.
Offline KamHillbilly
« Reply #4 on: August 05, 2017, 09:51:22 pm »
most of my floor joists in my house are tamarack even have some edging on some shelving done in tamarack mind you this is all indoors the only other thing I built with it is dock cribbing at the lake
Homemade Bandmill ,Clark 664b ,Case 780b ,Jonsered 670,630
Offline Baron
« Reply #5 on: August 07, 2017, 08:38:36 am »
Is it splintery like Hemlock? I'm starting to rethink having using it for decking. It may not like my bare feet.
Offline 69bronco
« Reply #6 on: August 07, 2017, 10:33:19 am »
I think it's worse than hemlock!
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #7 on: August 07, 2017, 12:06:42 pm »
Larch/tamarack is hell sawing and handling.  Little tiny slivers you can't really see all in your hands and such.  If I was using it for a deck I'd be sure to give it a good sanding before using the deck with bare feet!
Other than that, around my area larch is popular for decks and porches and such - lasts as good as pressure treated I'm told.
