Gearmatic 19 issues
Started by Woodboogah, July 20, 2017, 05:30:35 PM
Woodboogah
Hello All!  I come seeking some knowledge and see if I (we) cant figure out the issue I am experiencing.  Bear with me please
It all started when the O ring from the cap on the winch control inside the cab finally gave out.  No problem.  I replaced that.  Upon replacing the line that controls winching in started weeping....this is where my problems really start.  I got a new line and put it on.  I started to bleed system and couldnt keep pressure.  It would winch in if I really put pressure on the handle then slip a little.  I started digging a little but and found the compression fitting inside the small cover was weeping by.  I replaced the whole 1/4" line and started bleeding again.  I have the winch so it winches in (still with a lot of pressure on handle) under load I have to really reef on the handle and it still wont winch a mid size hitch.  When I lift handle to free spool it will release and free spools somewhat ok.  When I pull by hand I really got to pull but it eventually come free.  The drag adjustment is all the way out at the moment.  I was assuming since everything was working before replacing what I thought was minor stuff that bleed system and go!  Not the case.  I've never had apart passed where I am at and dont really trust myself to go further not knowing what I am doing.  Does this sound like a band adjustment issue, air issue still, or something else?   I am really at a loss not knowing much about them, and extremely frustrated.  Any insight, help, whatever would be greatly appreciated.      Before all this started it was working as it should pulling really strong.  I have taken apart controller to make sure rubber cups are intact and everything is clean and free from debris too.  Thank you
Keenan Logging & Tree Care, LLC
coxy
 :D welcome to the g matic world  they are simple to work on don't need 10 years of collage    if every thing was working fine till you rebuilt the control part you have air air and more air  to get the air fully out of the clutch side take the  big cover off there is 2 threaded spots in the cover to screw in the bolts to pull the cover just watch its heavy but not bad  after getting the cover off you will see the clutch line running through the winch to a cylinder that works the clutch bands loosen the line just as it goes in the cylinder to get the air out just don't for get to put the line on before trying to bleed  :-X  you can try to winch with the cover off just be carefull the out side brake band doesn't pop off  you will get a little air back in the line after you take it apart to put the cover back on but when I take the line apart I hold it up higher than the master control so fluid don't run out after the cover is on just bleed the crap out of it where the line goes to the little nipple that's under the small outer cover   as for the brake I never got air on that side of the control till the other day after working on the clutch side  I released the brake and bleed it on top of the winch 3 times and the brake worked fine  as I said I have never got air on the brake side of the control by working on the clutch side till the other day I guess first time for every thing  don't be afraid to rip in it they are easy to work on  ;D I'm shur other people will chime in with some other good tricks also  good luck keep us posted on what you find out  p.s don't forget to put a good rag in there to get the brake fluid so it don't go on the clutch or brake bands when bleeding the inside
Woodboogah
Thank you.  I'm dedicating my day tomorrow to getting it running.  I have never had this much of an issue with bleeding air out of the system!  Thanks again
Spartan
They can be a bear.  One thing I have experienced is this.  Sometimes the hydraulic fitting on the hose doesn't really fit that well on the flare fitting.  depending on what brand hose and thread pitch.  The result can be that although you think its on and tight, its not, and it won't visibly leak but will suck air.  I have had to reef on some of them to get them to seal, but be careful not to strip them.  also check the flange on the flare fittings to make sure they are not dinged or wore.  It does sound like an air problem to me to.  I use a mighty vac if I can't get it manually to suck the fluid through.  You also have two rubber brake cups. one in the clutch slave, the other in the master.  those can go bad and get cracks or holes in them that will leak pressure.  If you can't get it with bleeding, might be worth a shot to check those too.
Woodboogah
I dove into the guts of the winch this morning. Thanks to previous posts giving me some confidence. Anyways, I found a bunch of fluid and grime in there. The culprit is a tear in the rubber cup in side. How does that come out?  I'm assuming since bands are wet they'll need replacing?
North River Energy
What's the cup size?
I have a few spare, but I don't remember if they are for a model 9 or 19.
Spartan
You talking about the brake cup inside the slave?  take the rod out of the end of the slave, remove the rubber boot, then bump your clutch lever and it will push out.  you have a solid piece that will come out first, then your cup.  Most of those can get by with a 1", but if you can find one that is 1 and 1/32 that fits better.  Most auto parts stores will carry them.  crack the fitting upstream from the slave when you install it all back together, helps it push in easier.
take your bands out and spray them with brake cleaner and wire brush them,  unless they are falling apart, i dont think you need to replace them.
I clean mine that way and can break cable all day long.
coxy
are you talking about the clutch cylinder in the winch if so you can rebuild it in there they are a pita to get out most of the time they get damaged trying to get them out you can get the rubber from a parts store if the bands are real wet toss them in the trash I know some say bake them put them in cat litter  what ever else I just toss them I know there expensive but its not worth the aggravation to me pulling the winch back apart  one and done  :) when adjusting the clutch bands I use a hack saw blade between the band and drum
Spartan
I wouldn't replace anything until you know for sure the leaks are fixed.
Woodboogah
I ended up getting a rebuild kit and new bands.  If I am going to take it apart I might as well put all new back in.  The bands are really wet.  It looks like a straight forward job to do, maybe just time consuming?  We will see, have to wait for some dry weather.
coxy
after you do it a few hundred times it way less than a hour to do all the bands
Ed_K
 Hardest part is taking the big cover off  ;D .
Ed K
coxy
Ed_k the hardest thing I ever had trouble with was them stupid allen bolts on the gland cover they always strip out after a few times taking them out so now I put new ones in every other time its apart  the big cover is a finger pincher/smashing pile of poo ;D
Ed_K
 Coxy, I bought a short allen socket so I could push in on the socket wrench. They've held up pretty good.
Ed K
Woodboogah
Well I did it.  Everything went smooth.  Easier than expected.  Took my time and cleaned everything while I was in there.  Pulls like a son of a gun!  The only issue I am having is getting the winch to free spool enough so I can pull it by hand.  I can get it to spool out while idling machine forward.  Maybe still needs a little bleeding?
coxy
the brake line on top of the winch try that like I said I never had any trouble with any of my g matic getting air in the brake side while working on the clutch side till a few weeks ago I put it in release and bled a few times also you didn't put the brake drag to tight did you its the little thing on top of the winch I take mine out ya it free spools like mad with it out but so does most older jd winches just have to be a little careful when free spooling that's another reason for running 50-75ft of cable most times you never pull that much out anyway another thing you didn't loose any of them little shims did you  may also have the clutch bands to tight try backing them off a little  if you don't have any luck
Woodboogah
I had to replace brake cylinder, or rebuild I guess.  There was a tiny tear in there as well.  So everything is back to working.  I messed with it a bunch yest. and seems to be good. Still having a hard time in freespool.  It pulls hard, releases fine.  I can move the line but it feels like Ill blow my back out.  In the manual I have the picture for adjusting the brake is a black blob from being photo copied.  I have the drag adjustment out, all the shims were saved and back in.  I am going to run it today and hopefully after some time it'll free up some.  I did burnish the bands too.  If I cannot get it to loosen up I guess ill just be in better shape from pulling a hard cable
coxy
straight down from the brake cylinder on the bottom there it a cover with 2 bolts in it the big spring for the brake sets on it you flip it over to put more preload on the spring some of them plates you can get off some you cant get to and some the bolts brake off then its a PITA to drill them I have never turned the plate over for more preload I always spent 12$ on a new spring and every few years ill put a new one in there they do get week the first one I ever done was 1/8 shorter than a new spring
Ed_K
 I've been having the same problem. Took it apart again yesterday and am convinced that the only problem is my band material is to thick  >:( .  I could get the smaller band back out and used a rasp to shave it down some but I can't get the larger band out without taking the whole clutch and main casting out. The one thing I discovered is when you do this you can get the bearing off quite easily. There's 2 threaded holes in the casting you can screw 3" bolts into and draw the casting off. There's a c clip between the bearing and casting that needs to come off first tho.
Ed K
coxy
I had a new set of clutch bands that I tried to put in a 19 but was to thick had them in my shop about 3-4 years and a friend needed them didn't have much money at the time so told him to take them he put them in a 119 and they worked fine and showed me  if you look at the groves that them little cams set in to adjust the clutch bands some of the bands have wider groves in the and if you have the narrow cams and a wide grove they let the clutch band cock off side ways just a little and cant get them to adjust right every thing will be good till you go to winch that's when the trouble starts
pdxh20
And just a little more fat on the Gearmatic fire, since I'm almost done with a rebuild on the 119 on my '75 IH S-8 after removing it so I could manipulate it on my (steel) shop floor to get access to all the busted bolts and stuck plugs. Some notes and ideas I came to learn in the process may help others:
1. Never try to use anything but grade 8 bolts to push off the clutch plate or the big cover, regular bolts shear off and need to be drilled out, huge PITA since the holes are blocked by the the drum collar they push against. Even broke an easy out in one hole and had to drill that out too. In the end I bored 'em all out and went up from 1/2" to 5/8" (using a flat ground drill bit & bottoming tap) before I could get it popped off.
2. When pulling the gland and/or hydraulic tube from the end of the shaft, any side cocking will snap off the delicate cast-iron "tube" on the back side, right at the o-ring groove. $95 mistake...I decided to home-brew upgrade, and replaced the hydraulic tube, cup, o-ring and two small bearings (had to weld little bolts to the inner races to pull 'em out of their blind hole in the gland) with a Parker S-series live swivel threaded into a recessed 1/4" brass plug that goes in a tapped 1" pipe thread hole in the center of the gland where the bearings used to live. Used 518 sealant when I put the gland on and it seems to work fine.
3. I had to torch through every ball on the the upper drum bearing before the drum would come off). The bottom one I used a cutoff wheel on a grinder to slice into and fracture with a chisel, and still damaged the big seal under it, so had to replace it too.
4. Used a 10 ton porta-power sitting on the end of drum shaft to push up on a strongback shackled to the lifting holes in the casting webs on the drum and still had to bang it with a sledge when it was under full pressure to break the drum free so I could lift it up and off the shaft.
5. After everything was finally apart I power wire brushed (electric, bench, and air) every part and primed and then painted every non-bearing part before re-assembly. Every threaded part and bolt got replaced with grade 8 or cleaned and every one got Never-Seize before installation. Same for anchor pins, roll pins and other sliding surfaces.
6. All the bands were re-done on my backings by a local friction house for under $400 total and fit perfectly.
7. www.forestryparts.com has all the bits and pieces for less money than the local bearing and seal houses. The exception is that the master control and brake & clutch rubber cups can be had from the assortment kit behind the counter at the auto parts store.
8. I drained the oil & a bunch of water out of the gearcase before I started, after rolling it every which way on the floor to work on it and mounting it back on the skidder I decided to replace the drain plug at the bottom of the adapter housing. When i removed it, another quart of water and a pint of oil came out !, must have been trapped somewhere inside, or the "communication" hole between the adapter housing and the gearcase must have been plugged the first time, and rolling it around freed it up ? I put a 1/2" ball valve on a 45 street elbow (for clearance) in the drain hole so I can put a hose on it when doing a fluid change without making a mess.
9. A piece of 6" aluminum pipe works great to drive the shaft bearings on. Drive the lower one on first before lowering the drum onto it or you will never get the drum past the first raised area on the shaft where the top bearing goes.
10. Much easier to install the secondary (large) brake band and anchor pins before lowering the drum into place on the shaft.
This winch hadn't been used in 3 years or so and the clutch bands were stuck to the drum. The brake line was snapped off at the slave fitting and there was a ton of rust and dirt in the bottom of the clutch/brake side. Looks like an aircraft engine now...and it should be much easier to service now too.
'56 American crawler crane, Komatsu mini-ex, multiple Stihl saws, '75 IH S-8 cable skidder, 2000 F450 30' bucket truck, '95 Chev 4 x 4 2500 p/u, '05 Sprinter SHC 2500 van
mike_belben
That sounds funner than unicorn leapfrog, but not by much at all.
Praise The Lord
coxy
pdxh20 you only did half a rebuild  ;)  wait till you get on the ring a pinion side of the winch  :D its fun trying to get that little lock thing out its shaped like an L and a huge pita to get out of the hole on the shaft  to tighten the bearing by the r&p side   you have to pull the drum and its by the inner bearing on the drum but its for the shaft    I still have a  piece of the drum bearing floating around in my arm the inner bearing wouldn't come off the shaft so the brain surgeon I am I smacked it with a 10lb hammer and it exploded  and a piece went in my arm and never got it out   anyway sounds like you had a lot of fun doing your winch  :D
62oliver
My 119 has been good since I fixed it when I first got it. I keep it covered and make sure to pull it out at least every couple months. The only time it has given me trouble is when the reverser is in reverse :D, once I torn it all apart because of that, the good part being I got a little familiar with how it works, like my boy says "it's not rocket appliances". But I'm not making a living with it, I might feel differently if I was. :)
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
