Author Topic: Finally starting a Solar Kiln  (Read 2573 times)
Offline GeneWengert-WoodDoc
Re: Finally starting a Solar Kiln
« Reply #20 on: September 01, 2017, 03:18:09 pm »
I have seen lots of design modifications of the original VT kiln (1978) and many ideas were good.  Your design changes are awesome indeed.  Thanks for thinking and sharing.
Offline vfauto
  • TimberKing 2000
« Reply #21 on: September 04, 2017, 07:57:39 pm »
 Today's progress!
Not sure why some of these pictures  are distorted .
The definition of insanity is to do the same things over and over and expect a different result!
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #22 on: September 04, 2017, 09:22:06 pm »
I have no idea why but when I am using my iPad, I tap on the distorted ones and they undistort, I tap on them again and they redistort. Are "undistort" and "redistort" words?
They are now!  :D :laugh:
1992 LT40HD
The winds of change are blowing at hurricane force and I don't like it but good shall come even though I see not how.
Offline vfauto
  • TimberKing 2000
« Reply #23 on: September 05, 2017, 08:36:16 pm »
Same with IPhone
Offline vfauto
  • TimberKing 2000
« Reply #24 on: September 17, 2017, 01:57:36 pm »
Here is a update on kiln!  If pictures are distorted click on them and they will repair of themselves.
Offline DDW_OR
« Reply #25 on: September 17, 2017, 04:31:18 pm »
How are you going to load the lumber?
assume pallet forks. if so then you will need to make the ground in front of the doors level.
in this picture the ground on the left is lower than the ground on the right
this will cause the lumber being loaded to be sloped when loaded.
and maybe a mirror or wireless camera to see how the position of the load is as it is being loaded
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline samandothers
« Reply #26 on: September 17, 2017, 05:11:27 pm »
Looks great.  If you get chance can you post what the hinges look like on inside of door?
Offline vfauto
  • TimberKing 2000
« Reply #27 on: September 17, 2017, 05:41:11 pm »
The hinges are not on the inside????
« Reply #28 on: September 18, 2017, 10:14:09 am »
Sorry I was not very clear.  How are the hinges anchored on the inside.  You built up/backed under the hinge on the outside but on the inside of the door and kiln did you add a backing board?
Offline vfauto
  • TimberKing 2000
« Reply #29 on: September 18, 2017, 12:09:30 pm »
Door side has blocking and threw bolts, post side has 4.5 inch lags.
« Reply #30 on: September 18, 2017, 01:46:40 pm »
Got it!  Thanks
Offline D6c
« Reply #31 on: September 20, 2017, 09:09:11 am »
Looks great....I like your roof design.  I need to find time to build one myself.
Offline vfauto
  • TimberKing 2000
« Reply #32 on: October 01, 2017, 06:54:13 am »
Some progress  8)
Offline fishfighter
« Reply #33 on: October 01, 2017, 07:37:19 am »
What kind of paint you used? Looks great.
Offline vfauto
  • TimberKing 2000
« Reply #34 on: October 01, 2017, 01:29:10 pm »
 Behr porch and floor flat black because regular paint can that be put on the horizontal surface  and this is a very durable paint
Offline YellowHammer
  • There's a lot more to it.
    • Hobby Hardwood Alabama
« Reply #35 on: October 01, 2017, 10:07:55 pm »
Looking very nice!
Hobby Hardwood Alabama.com
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660, 2 Kilns
Offline btulloh
« Reply #36 on: October 10, 2017, 11:39:55 am »
Looking really good.  Any progress lately?  I'm looking forward to see some of your details for the rest of the build.  I really like what you've done so far.
HM126
Offline vfauto
  • TimberKing 2000
« Reply #37 on: October 15, 2017, 06:29:15 pm »
Offline btulloh
« Reply #38 on: October 15, 2017, 09:14:10 pm »
Looking good. Almost ready for a load of lumber.  You do nice work.
I can't really see in the picture, but it doesn't look like any blocking between the rafters where the fans are mounted. That needs to be sealed off to create the plenum effect for air flow through the stack.  Just an observation.
HM126
Offline btulloh
« Reply #39 on: October 15, 2017, 09:16:14 pm »
What kind of fans are you using?
HM126
