Author Topic: Finally starting a Solar Kiln  (Read 1341 times)
Offline vfauto
  • TimberKing 2000
« on: July 19, 2017, 03:13:45 pm »
Attached is a picture of the floor upside down because I was going to have it spray foamed until I got the cost. Now I am thinking of putting blown in insulation and sealing the bottom with corrugated metal.Any thoughts would be great.
The definition of insanity is to do the same things over and over and expect a different result!
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Finally starting a Solar Kiln
« Reply #1 on: July 19, 2017, 03:33:03 pm »
I would think pink stuff and plywood would be the best option for that. Could always do 2" thick foam but the pink stuff be quite a bit cheaper.
I knew what I thought I meant.
Offline btulloh
« Reply #2 on: July 19, 2017, 03:54:40 pm »
I used the pink stuff and plywood.  Some people use rat wire, but I had some extra plywood and nothing can get in to live there.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: July 19, 2017, 08:36:11 pm »
Make sure you make it mouse proof or they will take your insulation  away.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline vfauto
  • TimberKing 2000
« Reply #4 on: July 19, 2017, 09:54:19 pm »
I am worried the ply wood will rot
Offline btulloh
« Reply #5 on: July 19, 2017, 11:40:08 pm »
It was pt plywood.
Seems like corrugated metal would be fine. Lack of permeability could be a problem though. One of the experts should be along to comment on that though.  It should be able to breathe at the ends, so perhaps that takes care of it.
I'm just bumbling along here. Like most people, I try to use some of the stuff I have laying around when I can and not compromise the critical areas in the process.
HM126
Offline fishfighter
« Reply #6 on: July 20, 2017, 07:14:19 am »
If you use tin, get some steel wool and stuff it in the ends. That should keep small rats out along with snakes. I would just use some R30 batts. That should do the trick.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: July 20, 2017, 07:39:17 am »
I used fiberglass insulation to fill the floor joist bays and topped it off with the 2" rigid foam insulation.  The floor bottom is pressure treated 1/2 plywood.  The top was sealed with a polyethylene vapor barrier and topped with pressure treated 1/2" plywood.  Has worked great for my Nyle L53 dehumidification kiln.
Offline vfauto
  • TimberKing 2000
Offline btulloh
« Reply #9 on: August 12, 2017, 07:27:51 am »
Can't get to the picture.
HM126
Offline DDW_OR
« Reply #10 on: August 12, 2017, 03:32:59 pm »
i think these are the photos
TimberKing 2000, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline vfauto
  • TimberKing 2000
« Reply #11 on: August 14, 2017, 07:40:18 am »
 Those are the photos, thank you, how did you get them up and what is the proper procedure for putting pictures on this forum,it is a pain in the butt !
Offline btulloh
« Reply #12 on: August 14, 2017, 09:40:48 am »
In the list of forums, go all the way to the bottom to FORUM HELP, HOW TO POST PHOTOS.  Good info.
You're not the first one to find the photo thing to be a little awkward, but it's not bad when you get over the initial learning curve.  Whether is it's awkward or not, well, no big deal.  Everybody goes through it at first.  One thing I've noticed though is that pictures stay visible on this forum, which is a good thing.  I look at a lot of other forums where the pictures disappear pretty quickly.  So all-in-all, I'd say this is a good system once you get used to it.
Those are interesting piers.  Did you cast them yourself?  They look like the height is adjustable after the fact.  Cool.
HM126
Offline vfauto
  • TimberKing 2000
« Reply #13 on: August 28, 2017, 09:16:46 pm »
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #14 on: August 29, 2017, 11:49:57 am »
Lookin good!
1992 LT40HD
The winds of change are blowing at hurricane force and I don't like it but good shall come even though I see not how.
Offline btulloh
« Reply #15 on: August 29, 2017, 11:58:48 am »
Looks good.  That 2x6 framing will give you room for some good insulation.
HM126
Offline vfauto
  • TimberKing 2000
« Reply #16 on: August 31, 2017, 07:35:14 pm »
  Just a few more pictures of today's progress
Offline btulloh
« Reply #17 on: August 31, 2017, 07:49:56 pm »
I like the extra width.  It looks like you added three feet between the north wall and the sloped roof.
HM126
Offline vfauto
  • TimberKing 2000
« Reply #18 on: September 01, 2017, 06:37:33 am »
The total foot print is 8'x14'.We needed the ridge to be located there to achieve the 45 degree pitch and 32" south wall.
Offline barbender
« Reply #19 on: September 01, 2017, 02:44:30 pm »
Looks really good! Lord willing that I ever get time to build a kiln, my plan is to use pink foam board in the floor. What I have found to work really well is the adjustable spray foam dispensers. I used wood I joists in our house, and it was a bit tricky to insulate the rim joist with the I profile meeting it. So I cut foam board to shape, about 1/2" undersize all around, and then went around with the spray foam. With the adjustable tip, it meters really well to where it's almost like welding. The other nice thing is you can leave the gun and come back to it the next day, or month, and start spraying foam again, unlike the disposable cans that once you use some, you have to use it all or it hardens in the dispenser. Anyhow, I plan on putting board between the joists and sealing the perimeter with spray foam.
