Author Topic: Cook's All Metal Band Wheels  (Read 1083 times)
Offline FloridaMike
« on: July 11, 2017, 08:12:32 AM »
Search didn't find much info, so: How well do Cook's all metal band wheels work?  I'm looking at running 25" wheels with 1-1/2" bands and 1-1/2" shafts on my homemade 20.8 hp Honda powered band mill.
Thanks in advance for any firsthand feedback that is available!
Mike
Offline kelLOGg
  • Still learning more than I'm teaching
Re: Cook's All Metal Band Wheels
« Reply #1 on: July 11, 2017, 08:33:04 AM »
I have their 19" all metal and I have no problem with them. Cook is big on true and balanced wheels and they certainly are. Re-crowning is eventually necessary and I recently had mine re-crowned (after 12 years) and upon re-installing I measured the runout at <0.001 inches. A common opinion on the FF is that steel wheels cause blade curvature requiring rolling to make them flat again. Cooks disagrees saying that any wheel around which a band is turning will cause band curvature :P. With steel there is never a need to replace a belt, only occasional re-crowning.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, tandem trailer, log arches, trailer, tractor, hammer
Offline Grizzly
  • I wanna go camping!
« Reply #2 on: July 11, 2017, 04:46:34 PM »
I run a Logmaster which uses 30" steel wheels and other than that crown needing to be trued periodically it runs true and strong. Cooks have a good reputation so I wouldn't be afraid of their product at all. I've never experienced slippage but I've heard that too much lube will cause it. Maybe the same for belted wheels? I don't know.
From all that I've read on the forum band maintenance is required of all makes and manufactures, so I'm not sure how much I'd take that into consideration. I've had to correct flatness on brand new blades I took out of the box.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws
   2149 - 111S - 90?
Cooks Cat Claw & Dual tooth setter
2000 Miners 3-31 Board Edger
Offline longtime lurker
« Reply #3 on: July 11, 2017, 05:02:40 PM »
Never see a big band that ran on anything except steel wheels. If it's right for the big gear, you'd think it's the material of choice for the little stuff as well.
Offline petefrom bearswamp
  • Location: Finger Lakes region of NY, no more FL in winter
  • made 70-10 and still feelin pretty darned good!
« Reply #4 on: July 11, 2017, 06:04:27 PM »
Are the big band wheels crowned?
Every mill mfr has their pet style of wheels and or belts  and blades
IMO whatever works for you is good.
after trying several different styles of belts but not steel wheels I stick with orange.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline drobertson
« Reply #5 on: July 11, 2017, 06:06:03 PM »
yea, there's no reason you should feel hesitant.  It's an industry standard on many, many band saws, production wise.  Not much else to say,
Offline FloridaMike
« Reply #6 on: July 11, 2017, 06:07:20 PM »
Thanks for the info... I have ordered a set!
Mike
« Reply #7 on: July 12, 2017, 05:17:22 AM »
Offline Pabene
« Reply #8 on: July 12, 2017, 12:53:38 PM »
My saw mill has 24" dia. steel wheel. It is real good steel not cast iron. I have had the saw sins 2005, it is not used every day but I have made a lot of boards. The wheel has crown. The "top" of the crown was in fact a flat (cylindric) surface, 1/4" wide. After the 12 years I can see that the contact part of the crown top has a little wear, its now about 9/32" wide. The function is still very good. I have lubricated the blade with some drips of thin oil, maybe every hour, from the beginning that was made to keep the blade free from resin and rust. I can hear from the noise when I think the blade needs a little oil. (I have plans to add a "oiler" with felt wick but its not performed yet). If i would use thicker oil, the blade will "float" on the oil film and "jump off", I know that the hard way.
Online JB Griffin
« Reply #9 on: July 15, 2017, 10:14:47 AM »
The Baker at work has 36in steel wheels. Have to have the wheels crowned every 6mo. or so but thats around 6-700mbf.:)
2000 LT40HYDD33-RA, Prentice 160, Frick 2 saw gang edger '96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c
1.5 million bdft sawn with a Baker Dominator and counting.
Online boscojmb
« Reply #10 on: July 16, 2017, 09:11:03 PM »
I'm a little bit late to the party, but have something to add.
Small sawmills use rubber tires and get away with it, The next step is big pulleys with belts, the biggest sawmills (and some others) use crowned steel wheels.
Steel wheels are a  huge improvement over belted pulleys, as far as production and lumber quality goes.
I have crowned steel wheels and love the speed that I can cut and the quality of my lumber.
Steel wheels are LOUD. I don't like the noise. I think this is why many manufacturers do not use crowned steel wheels.
If you are going for production, crowned steel wheels are the way to go. If you are building a small hobby mill, belted pulleys may be more enjoyable.
I hope this helps
John B.
Log-Master LM4
Offline 5quarter
« Reply #11 on: July 17, 2017, 12:50:46 AM »
...Steel wheels are LOUD. I don't like the noise. I think this is why many manufacturers do not use crowned steel wheels.
I hope this helps
If you're wearing ear protection, it shouldn't be an issue. I wouldn't turn the key on my mill without them.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #12 on: July 17, 2017, 04:34:38 AM »
Ear protection ?
I can talk to someone when my mill is cutting.
It has a Honda gas engine. I'm sure glad I don't have
a lot of noise.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline ladylake
« Reply #13 on: July 17, 2017, 06:34:27 AM »
 No way I'll run any loud machine without ear protection, plus the ones with am  fm radio work real good. If I want to talk to someone I take them off.  Steve
