Author Topic: What motor to use for powerfeed on homemade mill.  (Read 1543 times)
Offline Joe Hillmann
« on: July 08, 2017, 06:42:54 PM »
I am thinking of building a power feed for the carriage on my homemade mill but don't have a clue what type of motor I should be looking for that will work.
I don't know what type of 12 volt motor could handle being run constantly without burning out.  I had thought maybe a winch motor but I don't know if it would last.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: What motor to use for powerfeed on homemade mill.
« Reply #1 on: July 08, 2017, 08:32:10 PM »
E-bay... Tarp motor. 12v
I went with wheelchair motors. 24v is easier to find.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
« Reply #2 on: July 09, 2017, 12:49:20 PM »
I assume you mean a tarp motor like off a dump truck?  What would you use for speed control, a PWM control?
Offline Kbeitz
    • My Hobbies
« Reply #3 on: July 09, 2017, 01:01:59 PM »
Go to E-bay and just type in tarp motor. It's one of your only choice for a 12v
gear motor. I don't know the rpm but I watched them run at our local junkyard
and the rmp look about right. Google says 60 RPM
Then do a search for
DC 10-50V 60A Motor Speed Control PWM HHO RC Controller 12V 24V 48V 3000W
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #4 on: July 09, 2017, 05:56:19 PM »
Of course a gear motor isn't your only option.  Wood-Mizer uses a 12VDC motor with v-belt pulleys to do the speed reduction.
Offline Kbeitz
    • My Hobbies
« Reply #5 on: July 09, 2017, 08:36:59 PM »
I don't see how you could use a motor with out some kind of gear reduction..
The carriage does not move very fast.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline ssspeciale
« Reply #6 on: July 09, 2017, 09:10:41 PM »
I used a  12 volt 2500lb winch and a pwm. I cut a section of the winch spool out in the center until it was about 1.5"wide and added a 3"diameter chunk of delrin plastic to increase the diameter so the travel speed would be faster. I use the pwm to regulate the speed going forward cutting. The return speed(reverse) is full speed. You can change your full speed by changing the diameter of the delrin you put on the spool. I would say mine with the 3" is around 80 to 100 feet per minute.
3"
Offline larrydown60
« Reply #7 on: July 09, 2017, 09:23:29 PM »
I used a 12v steering motor $40.00 for a 08 Chevy Cobalt works good with a $9.00 speed controller on forward speed only
Offline Ga Mtn Man
« Reply #8 on: July 09, 2017, 09:34:19 PM »
"... Wood-Mizer uses a 12VDC motor with v-belt pulleys to do the speed reduction."
« Reply #9 on: July 10, 2017, 10:39:33 PM »
3"
When you are using it all day does the winch over heat?  I had thought of something like that but didn't know if it would be up to the task without burning out,  I also wasn't sure if it could be controlled with a pwm controller.
« Reply #10 on: July 10, 2017, 10:42:20 PM »
does that require a pwm or a stepper motor controller?  I looked at pictures of it and can't tell if it is a gear motor or a stepper motor.
« Reply #11 on: July 10, 2017, 10:43:32 PM »
I think I would prefer a gear motor over v belts to slow it down,  unless there is a benefit I'm not seeing to using v belts.
Online paul case
  • Original wearer of the PCM.
« Reply #12 on: July 10, 2017, 10:55:50 PM »
I guess if I was doing it I would look at whats available through surpluscenter.com.
PC
pc
Offline Kbeitz
    • My Hobbies
« Reply #13 on: July 10, 2017, 11:05:37 PM »
Stepper motor controllers can only be used on stepper motors.
One of the reasons I used wheelchair motors is the low amps they draw.
Winch motors are high powered motors that draw high amps.
You best have a real good charging system if your going to use one.
The controller would also be very expensive for high amp motors.
Wheelchair motors are geared to turn a 12" wheel at walking speed.
That works out great for the carriage speed. Used wheelchair motors
are sold cheap on E-bay and if you have a junkyard around most of
them have old electric wheelchairs in them. I see about one a month
come in to our local yard. Another neat thing about the wheelchair
gear box is that they have a quick disconnect leaver. For raising the
carriage a wheelchair motor connected to a worm gear winch works
great.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline fishfighter
« Reply #14 on: July 11, 2017, 07:30:49 AM »
Any pictures of how you have it rigged up?
I'm using wheel chair motors and it's control still. I have to have both motors hooked up for the system to work and I used two lawn mower batteries to power it up. Been wanting to drop to one motor the way K has posted. Just haven't had the time to do it yet. :(
Offline ssspeciale
« Reply #15 on: July 11, 2017, 08:38:33 PM »
It has been on the mill for about a year so far without any problems. I doesn't get hot I don't think its working hard enough to cause any problems. The whole set up only cost about $110. I used the cable that came on the winch($50) instead of a chain. I also bought 2 pulleys with bearings for a garage door cable and a turnbuckle. I used a drum switch(ebay) for fwd/rev and the pwm (ebay) and the wire that came with the winch. All the parts cost about $70. It runs off the battery that starts the mill engine (25 hp Honda).no issues with the engine keeping the system charged.
Offline larrydown60
« Reply #16 on: July 11, 2017, 10:22:25 PM »
Joe Hillman I am not sure what you mean? I am using a speed controler on forward speed only. I burned up the first controller because it was only 20 amp rated I ordered a 40 amp one it should be here by Friday.
Offline larrydown60
« Reply #17 on: July 11, 2017, 10:28:02 PM »
fish fighter, I will post more pics tomorrow of how it is wired up there are pics of the motor with gears and chain setup, if you need special pics just tell me what you want to see and I will post them
Offline fishfighter
« Reply #18 on: July 12, 2017, 06:32:54 AM »
Thanks Larry. You said you paid $40 for that motor. Was that new or a used motor?
With the wheelchair motors, I been very happy with it. Guess I really need to take the time to swap it over with the controller like K has posted.
Offline bandmiller2
« Reply #19 on: July 12, 2017, 07:03:29 AM »
Forget low volt electric go hydraulic and add a log turner too. Frank C.
