Saw in cedar pile
Started by bucknwfl, July 06, 2017, 04:28:50 PM
bucknwfl
https://forestryforum.com/gallery/displayimage.php?pid=228616
Found this old saw in a pile of old ERC log we were salvaging
Buck
If it was easy everybody would be doing it
paul case
I believe that is a board edger.
PC
pc
Yup, I'd go with "most of an edger"
This is the modern version.
http://www.youtube.com/watch?v=B322Q7NoZR4
Kbeitz
Wow.... I would be fixing that back up...
Love machine shop work
and Wood work shop work
And now a saw mill work
bucknwfl
Quote from: Kbeitz on July 06, 2017, 06:18:30 PM
W
Kbeitz I am sure you would have it back in working order in no time. It is all your if you want it.  I have a friend that has a new cook's mill and edger. A friend that recently bought a new property had a bunch of old cedar logs piled up from an old mill site.  I figure there are 100-120 logs all heart wood the sap wood is long gone. I figure they have been laying there for at least 15 years
Buck
Kbeitz
I'm making arrangements to get it picked up.
You put a real smile on my face.
Slingshot
   Looks like one of these....Bell Saw twin blade edger.
Look around for some more parts.... candle_smiley
____________________________
Charles       sling_shot
Kbeitz
whitepine2
  Yep a Bellsaw edger I've got one just like it,the one I got is probably
an older model as it has flat belts instead of the V's on the one shown.
bucknwfl
I have plans to back at the site early in the morning to load up the edger. I have looked around but I have not seen anything else. But I did not see this till we uncovered it and there are 5 or 6 big piles of logs.  Who knows
Buck
Kbeitz
I got it home. Now the fun begins.
Thanks again...
Ljohnsaw
No doubt that you will be able to fix it, but, oh, what a job that is ahead of you.  Then again, you will probably have done by the morning ;)
John Sawicky
grouch
Those pulleys sure did take a beating.
Find something to do that interests you.
Kbeitz
Who's waiting till morning ?
I got everything moving even the slide.
I do think this will take me a while.
First thing tomorrow I'm making a base for it.
I don't like working on the ground.
I will start a new posting on this rebuild.
Kbeitz
Quote from: grouch on August 17, 2017, 07:36:52 PM
Nothing I can't pound out.
But I might change to V-grove belts.
grouch
Quote from: Kbeitz on August 17, 2017, 07:38:26 PM
How about cross-linking the two threads when you do?
bucknwfl
It looks different already. It sure was nice meeting Joe. I carried it to work one morning met Joe at his son's house and loaded it on his trailer (he has pictures)
I believe he hauled it to Georgia and then to PA. It has quite a few miles on it now
Buck
Kbeitz
Kbeitz
Quote from: whitepine2 on July 07, 2017, 02:44:12 PM
So... Are you happy with it ? Does it do what you want.
What is the widest board that you can make ?
How many HP does it take to run it ?
Thanks.
whitepine2
Quote from: Kbeitz on August 18, 2017, 04:24:17 AM
Thanks.
Yep I like it works good,I used a 13 HP kobota tractor rigged it up to run
off the PTO. It will take some power if edging thick oak the one I got has three saws
it was rigged to cut 2 inch off of one side as well as the adjusted blade cut. Don't know
why it was rigged this way,but I kept it and just edge it without using the first saw.I have
never had trouble with flat belts but I think V would be better. A fellow had one rigged up
with a two cylinder Wisconsin baler engine worked fine,you will need to mount engine
on top to get right rotation I crossed two long V's to make it turn right off the PTO
                                            Hope this helps W.C.W.
Kbeitz
Thanks. I got a 14hp Kohler engine that I'm going to use.
