Author Topic: What kind of tree is this?  (Read 416 times)
Offline Dieseltim
  • M-14 Project
« on: July 02, 2017, 12:35:46 pm »
Im usually good at identifying trees, but this is one I don't know.  Anyone else know what this might be?
Offline JBlain
  • Forestry, woodworking, mushroom harvesting
Re: What kind of tree is this?
« Reply #1 on: July 02, 2017, 12:59:54 pm »
Maybe an spruce log? Looks like it has been sitting a while.
Josh
Offline Dieseltim
  • M-14 Project
« Reply #2 on: July 02, 2017, 01:07:21 pm »
Not really much spruce here south of Atlanta Ga.
I'm thinking maybe it is a large Bradford pear. But, I've never seen one this big before. Usually the wind breaks them before they get bigger than 18 inch.
I have 2 logs, probably from the same tree. They are about 12 ft long and 20 - 24 inch. They seem solid. So, I'm planning to cut them to see what they look like inside. Lol
Online Ga Mtn Man
  • Y'all can call me GMM
« Reply #3 on: July 02, 2017, 01:24:17 pm »
I don't know either but you might have better luck if you post it in the Tree and Wood ID board.  Or wait long enough and admin will likely move it for ya. :)
Offline paul case
  • Original wearer of the PCM.
« Reply #4 on: July 02, 2017, 02:56:31 pm »
some of our cherry looks like that.
PC
2013 LT40SHE25 and 3 blade Baker edger,  WM 94 LT40 hd E15. Cut my sawing ''teeth'' on an EZ Boardwalk
pc
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: July 02, 2017, 05:34:37 pm »
   My first thought was Spruce. Does it have a row of limbs about every 2'? I have an old Christmas tree patch of Norway spruce on my place and they look a lot like that.
   I can't tell without the needles or such but was wondering if some kind of pine or Hemlock or such.
   Would be nice to be able smell the log and see more about it.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #6 on: July 02, 2017, 05:43:48 pm »
My first impression was spruce....wavy lumber....bring me something else.   Would help to see fresh cut end.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Dieseltim
  • M-14 Project
« Reply #7 on: July 02, 2017, 10:40:57 pm »
I'll post more pictures once I cut it into boards.
Offline Dieseltim
  • M-14 Project
« Reply #8 on: July 03, 2017, 05:04:53 pm »
Ok got the first one cut this morning. Make some 8/4 live edge planks about 18" wide by 10' long.
Offline Dieseltim
  • M-14 Project
« Reply #9 on: July 03, 2017, 05:08:01 pm »
Even got about 6 pieces that can be book matched.
Offline Dieseltim
  • M-14 Project
« Reply #10 on: July 03, 2017, 05:13:20 pm »
Oh yea almost forgot, wide rings, fast growing, no noticable smell.
