Author Topic: Stain and finish on hickory  (Read 643 times)
Offline Leegej
« on: June 19, 2017, 09:49:10 AM »
Getting close to putting the finish on a hickory dining room table. I'm not looking to "stain" it, just something to really make the grain and colors of calico hickory pop. Maybe something like linseed or ting oil? I have used danish oil in the past.
Then I need a durable topcoat. I've struggled with getting a good and smooth finish in the past. I'm looking into an HVLP spray gun to give spray finish a shot.
Offline Den-Den
    • Dennis Wood Art
Re: Stain and finish on hickory
« Reply #1 on: June 19, 2017, 03:47:02 PM »
I like thinned tung oil on Hickory/Pecan to bring out the color with lacquer for a top coat (after the tung oil cures a few days).  Oil based polyurethane is a durable finish but takes more time and work to get it right.
Offline Leegej
« Reply #2 on: June 19, 2017, 05:15:27 PM »
How much do you thin it, and what with? Do you spray on your lacquer? I'm trying to find a HVLP set up that won't break the bank but don't know much about it!
Offline drobertson
« Reply #3 on: June 19, 2017, 07:18:38 PM »
Looks good to this point, waiting to see the finish.  Surely you will prevail.
Offline Jemclimber
« Reply #4 on: June 20, 2017, 10:58:47 AM »
There is a big difference between tung oil and tung oil finish. Pure tung oil usually takes quite awhile to polymerize/cure. It can also easily be freshened up in future years and has a "soft" appearance.  Also just fyi danish oil is not just oil, it's a blend of resin, solvent, and some type of oil.
I personally wouldn't use lacquer on a kitchen table. It's very susceptible to solvents, such as acetone in fingernail polish.  I have girls so ask me how I know where they leave used fingernail polish rags.
lt15
Offline Den-Den
    • Dennis Wood Art
« Reply #5 on: June 20, 2017, 11:40:59 AM »
I use "Pure Tung Oil" thinned with mineral spirits (60% mineral spirits, 40% tung oil).  Wipe on a generous coat, wipe off any excess and let cure at least 3 days (a week is better).  Yes, spray the lacquer.  If you don't have spray equipment, the rattle can lacquer from Home Depot (Rustoleum brand) is pretty good.
Poly is a more durable finish for a table but poly is miserable to repair if damaged does occur (it will).
Offline Leegej
« Reply #6 on: June 20, 2017, 12:37:05 PM »
I'll try the tung oil on some scraps and see how I like it. I'm looking at buying a graco FX3000 gun for spraying. Seems to be highly reviewed, and won't break the bank.
I've seen first hand the damage nail polish remover does to a table, but I like the idea of easily being able to touch up the finish.
