serving trays for a winery
Started by tule peak timber, June 15, 2017, 07:34:32 PM
tule peak timber
So I'm pitching the owner of a new small winery about why he might want to go with us. One of my ideas is to take trimmings from his vineyard and turn them into serving trays, see pics attached. My guys are used to working in wood that requires a forklift -and this is a little different. Rob
John S
I am curious to see where your creativity is going this time.  Looking forward to seeing a completed prototype.
2018 LT40HDG38 Wide
tule peak timber
I posted this to see who might be curious. I will make progress posts on the tray development as well as the other interior millwork . For today we staged the woods going into the kiln prior to fabrication.Got to make sure that I have all the parts and pieces ready for fall delivery. Cheers  Rob
69bronco
Crusarius
The only thing that I know is that you ain't crazy, so I'll just follow along.   :P
Savannahdan
I'm here and always enjoy these trips.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
breederman
Together we got this !
Ljohnsaw
Slingshot
I'll try to catch up when I find out where I am..........
___________________________
tule peak timber
While the grape vines are drying, we prepped a canyon live oak table today for pickup this weekend. The guys are hand rubbing out to 2000, then we get the machines out...Cheers  Rob
drobertson
yep, riding right along with the rest,, mighty fine finish work, It does start with a good foundation, and preparation, you are very generous with sharing your craft skills..
tule peak timber
This site is a good place to share , and learn.
tule peak timber
Hah, Now that you mention it......
The price now goes up. You are very welcome. :D
tule peak timber
spanks alot When are we going to set up the west coast version of the pig roast ?
21incher
tule peak timber
So the vines are getting dryer and we re-wrapped them today for additional compression. Meanwhile the guys in the shop keep working on more tables and I'm building some teak countertops for the wife's new kitchen A few pics of the sink setup today. Major thinking on subsetting the sink edge perfectly flat with the wood countertop. Certainly a challenge... Glue up first thing tomorrow morning.My wife has been away for a very long time dealing with a family issue and I hope she is  surprised when she gets home next week. Cheers  Rob
Jemclimber
"dealing with a family issue" sounds mentally taxing, so hopefully this nice surprise brings some relief.  It's always nice to see your work!!!
lt15
DeerMeadowFarm
tule peak timber
Yup, life is full of curve balls and I'm up to bat............
samandothers
Always struggled hitting a curve but, when I did it sure felt good!
VT_Forestry
Quote from: tule peak timber on June 28, 2017, 08:57:53 AM
Well, based on what I've seen, you take those curve balls and knock em out of the park
Forester - Newport News Waterworks
tule peak timber
I spent the day cleaning up the sink. I used Gorilla glue to set the sink because it adheres well to sanded metal. But it also foams up and makes a big mess . So my solution was to set the sink about 50 thousands below the wood surface then carefully flat sand the glue overflow. Next I dragged a thin hacksaw blade between the sink and the wood creating a kerf about 1/16 inch deep . Took several hours to clean out the Gorilla . So now I have a perfect outline of the metal to wood which I then filled with epoxy. There is a slight amount of epoxy overlay and a lot soaked into the end grain causing the little bit of shadow. Now here is the trick -there is an oiled sample  board in one of the pics showing the eventual color of the top next to the thin epoxy soaked transition (the kerf ). Tomorrow I sand and blend the wood to the steel seamlessly and later the final finish colorwise will  blend right into the transition .  Cheers Rob
