Dyes for leak detection
Started by nativewolf, June 14, 2017, 09:24:55 PM
nativewolf
Anyone used leak detector dyes that are visible with blacklight?  My first experience was yesterday with a friend showing me how he used it to find  brake line leaks.  I tried to use it to find an intermittent leak on my Hino water cooling system today but no luck.  I've replaced a thermostat and since then can't get it to leak and I don't think it was leaking at the thermostat.   Dye kit went in this evening and ran it for 30 mins and still no leak.  I'll put a load of lumber in tomorrow evening and drive it a bit til it gets really hot.  Just curious if others have used them.
We'll see what happens when it gets hot.  Regardless it seems that it would be great for finding leaks in hydraulic lines but I don't know if the dyes work with hydraulic oil?
Liking Walnut
mike_belben
Theyre common for refrigeration leaks.
Praise The Lord
nativewolf
So I learned.  I hear about people having trouble finding other leaks and I'm certainly having trouble with the water leak, wondered how common it is to use them.
Liking Walnut
BargeMonkey
 I first saw the dye testing doing EMD repair with MSI, seen the dye for fuel and for coolant leaks, never for hydraulic oil. Worked good if you had a cracked head or injector with a hole in the body you couldn't find, see the dye leak down inside the cylinder with the light.
Stoneyacrefarm
We use the hydraulic dye all the time.
I'll find the information and post it.
Work hard. Be rewarded.
mad murdock
We just use the black light for oil leaks, shows up a bright green color.
JLeBouton
I've seen a bright orange dye used in the hyd oil on processing machines. Helps spot a leak when there is snow on the ground.
