Author Topic: Sterilize air dried wood  (Read 2252 times)
Offline samandothers
Re: Sterilize air dried wood
« Reply #20 on: August 07, 2017, 07:16:32 pm »
Flat rock,
Did you build your chamber?  I continue to put off an attempt but have not ruled it out.
Offline thecfarm
« Reply #21 on: August 07, 2017, 08:12:01 pm »
farmfromkansas,welcome to the forum.
Do you have a mill?
Offline farmfromkansas
« Reply #22 on: August 07, 2017, 11:22:31 pm »
Had an MP32 for about 10 years.  Mostly my own use, sawed a little for neighbors and friends.  Air dried all my lumber, oak and walnut work ok, but ash and elm mostly go bad to borers and ppb.  Want to make a better way to dry and store lumber, including sterilizing and killing bugs.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #23 on: August 07, 2017, 11:33:53 pm »
FFK,
Welcome to the Forum, where are you in the land of OZ?  I'm near Eudora, in Johnson County.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer.
If you call and my wife says "He's sawin logs", I ain't snorin'.
« Reply #24 on: August 08, 2017, 07:30:15 am »
Saline county, near Gypsum.
Offline flatrock58
« Reply #25 on: August 08, 2017, 10:53:28 am »
samanadothers.  I am still planning on building a chamber, but need to finish my workshop.  I started it last summer and it has progressed slowly since I work on it by myself between other projects.  I am getting closer to having it done.
My plan is to build a 7'x7'x12' insulated chamber.  It will have two 1'x8' insulated doors that can be opened to let in the hot air from the solar collector.  then at night or when sterilizing they can be closed and the air rerouted and halogen lamps can be used for heat.  At least that is my plan.  Gene may have some input that will change that plan.   My quick crude drawing is attached.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #26 on: August 09, 2017, 07:13:05 am »
Flatrock, my plan is very similar to yours. Please keep us updated, I was thinking of thermostat controlled vents that would open and close both vents. I've got part of a walk in cooler I'd like to use for chamber, just need to find a few more pieces.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline GeneWengert-WoodDoc
« Reply #27 on: August 09, 2017, 06:02:49 pm »
The collector can be attached to the side at roughly a 45 degree angle.  The reefer wall itself should not be used.
Offline 69bronco
« Reply #28 on: August 09, 2017, 08:36:49 pm »
Gene, would you clarify? Using reefer panels for box, not collector.
« Reply #29 on: August 10, 2017, 07:05:05 am »
My comment about the reefEr collector is in reply to the comment in #19.
For a kiln, we want to have very good insulation for the walls and floor.  With fiberglass, 2x6 is better than 2x4.  2x4 is ok for polystyrene insulation panels.
« Reply #30 on: August 20, 2017, 06:52:08 am »
 went to check out a reefer trailer for sale.  The axle had been torn off, and the floor is broken and has about a 6" hump.  Wonder if driving my skidsteer on the hump would push it back down flat.  The guy will deliver the trailer, and put it down flat on the ground.  Need to get a couple chunks of hollow core concrete to put one under each end.
Offline YellowHammer
  • There's a lot more to it.
    • Hobby Hardwood Alabama
« Reply #31 on: August 20, 2017, 09:32:34 am »
Kiln floors really need to be dead flat as the wood stacks will conform to them as they dry.  If it can be shimmed, that would work, but flat floors, when fully loaded, in kilns are very important.
Hobby Hardwood Alabama.com
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660, 2 Kilns
« Reply #32 on: August 20, 2017, 05:38:26 pm »
The hump is right in the very back of the trailer, over where the axles attached underneath. The frame pieces under the floor are bent, but only in about a 4' area.  It would have to be pushed down to allow the use of a cart to roll a stack of boards into the front of the trailer. Maybe if I scoop up a bucket of gravel, and roll the skidsteer back and forth over it,  would push it down flat. The trailer is 53' long
Offline BigZ La
« Reply #33 on: August 20, 2017, 07:00:29 pm »
Could you block the track up and still use it. You would only lose a little head space.
« Reply #34 on: August 23, 2017, 08:02:27 pm »
Thinking about maybe cutting half way through the steel floor joists before putting the thing on the ground, so it would come down easier.  If I put a concrete chunk right under that part of the trailer, it would not be able to sag.
Offline PA_Walnut
  • Wood is my sanity break.
« Reply #35 on: August 24, 2017, 07:12:59 am »
What are the requirements for "sterilizing" material that comes from a quarantine area? Is there specific verbiage as to what needs to be done to meet the restriction?
Thx
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, locust and pine.
LT40HD Wide 35.9Hp Diesel
Kubota L4060 Tractor/Backhoe
« Reply #36 on: August 26, 2017, 08:12:25 am »
Because it is difficult for many people who are inspecting or enforcing the law to determine the species and if there is a valid sterilization, the requirement is something like no wood movement if the wood has bark.  Dried lumber does not have such requirements within the US, but lumber exported does.  Exported wood requires a third party certification and each piece needs to be stamped with a ink stamp indicating certification.
Offline PA_Walnut
« Reply #37 on: August 26, 2017, 08:16:43 am »
OK. Thanks. So, does air-drying material with bark removed satisfy the quarantine restrictions?
« Reply #38 on: August 27, 2017, 09:23:04 am »
Each state and region are different.
Offline TractorBoy78
  • Rather saw than go to the office!
« Reply #39 on: Yesterday at 12:25:57 pm »
I built a foam board box and am using 4 plug in oil heaters as heat source.  Have been thru several versions.  Current one holds temp at 145 degrees F and will hold 10' length.  Have inexpensive 2 prong moisture meter, remote thermometer, and infrared thermometer.  Remote thermometer that I place in box reads same as infrared thermometer when measured.  Saw in a chart that 140 degrees would sanitize a 4" thick by 12" specific gravity wood of 35 in about 300 minutes starting at a 25% moisture content.  I am thinking 24 hours in the hot box should sterilize oak 2.5 inch slabs.  Notice variance in moisture content from Center to outside of slabs by about 7%.  Have had red oak starting at 21% moisture content in for about 24 hours.  Trying to run it to sterilize and realize less than 10% moisture content.  Am I heading in right direction?
