Broken Crankshaft on Kohler 25 HP on LT40 HYD
Started by DR_Buck, June 12, 2017, 08:34:50 PM
DR_Buck
Today, with no warning I have had my most serious problem with my LT40 HDG25.   14 years, 954 hours and nothing close to this has happened.   The crank shaft on the Kohler 25 just gave out and snapped right off where it exits the engine.
I can't even imagine what would make this happen aside from some kind of defect in the shaft metal.   Late last summer I replaced a failed drive belt, the first one, original to the new mill,  and installed a new one in it's place.  The drive belt tension was set to the correct tension using a gauge and everything has worked fine.   Until about an hour ago.....
Any fix is going to be expensive.   Either a new engine or complete rebuild of the old one, which I have no time to do right now.       Anyone have any ideas on what could have cause this?
jmouton
maybe the metal was made from old dylithiom crystal metal,,,,,scottie might know
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
DR_Buck
Obviously, I need to get this fixed so I need to look at options.     Has anyone replaced the Kohler 25/28 Command Pro with the Kohler  35 HP V-Twin?   More HP is not a bad thing.
GDinMaine
It seems like the result of 954 hours of operation under side load. WM came out with an add-on part that serves to support the end of the drive shaft on certain engine models. I know this does not help you much, but it appears this is an issue on mills powered by other engines as well.
It's the going that counts not the distance!
WM LT-40HD-D42
I wonder if WM is offering the "crank kit" for the smaller engines to prevent this in the future?
Here is what WM has listed as replacement engines:  LINK
DR_Buck
Quote from: Magicman on June 12, 2017, 09:19:57 PM
I saw that.   There is nothing showing replacing the 25 HP Kohler with the 35 HP V-Twin.    I might have to make a call tomorrow.
Peter Drouin
Wow, not good, A new motor will be a lot of $$
954 HRS is not much time.
A&P saw Mill LLC.
License NH softwood grader.
sealark37
I would check the small engine parts distributors for a price on a new crank.  You will need engine serial number, model number, and possibly an arrangement #.  It might be big bucks, maybe not so much.  Regards, Clark
POSTON WIDEHEAD
Will the crank still turn?
I was wondering if something locked up and made it snap.
captain_crunch
my thought why nother bearig  on end That lots of load on  Shaft
Brucer
That certainly looks like fatigue failure. In other words, it wasn't caused by a sudden overload. Side loading will cause the sort of stress that leads to fatigue, but in theory the manufacturer (WM) would have kept the side loading below the fatigue limit. However ...
Fatigue failure has a statistical component to it. Most will not fail but a few will. 2580 hours on mine and not a problem (but I'm sure going to take a closer look at the 2600 hour service).
Bruce    LT40HDG28 bandsaw
Kbeitz
I have no idea if it's the right model but E-bay has a 25 HP Kohler crank for sale
for $100.00 right now.
Love machine shop work
and Wood work shop work
And now a saw mill work
DR_Buck
Quote from: POSTONLT40HD on June 12, 2017, 10:24:01 PM
    Still runs great.    Just no way to apply any load to it.    :-\
Quote from: sealark37 on June 12, 2017, 09:46:48 PM
Quote from: Kbeitz on June 13, 2017, 03:25:03 AM
  As of right now there is almost zero chance of me taking the time to rebuild it.  I may throw it into a corner for a future project.    I am seriously looking into seeing if I can up-size to the 35 HP Kohler.    I am calling Wood-Mizer this morning.
ladylake
  Don't hear much about Kohler cranks breaking, maybe just a bad one.  I think you can get by with running the belt a little looser on a gas motor compared to a higher HP diesel.  Does WM have different specs for the belt tension between lower HP gas and higher HP diesel motors, if not they should.  Steve
Chuck White
Won't help you now DrBuck, but maybe for us that have this same engine, it wouldn't be a bad idea to mount the alternator on the other side of the engine in order to take some of the side pull tension off of the crank shaft!
I know there are different tensions, but right now, both the blade drive system and alternator pull sideways the same direction!
Just sayin!
SineWave
Just for grins, I'd ask Kohler about it. Seems to me you should be able to get more than 1k hours out of it, even with extreme side loading, before fatigue failure.
And if Kohler says "Boo," then I'd ask WM about it.
Seems to me that if it's not defective, and less than 1k hours is all that one can expect, then some engineer somewhere needs to answer for this.
I'd raise hell about it.
TKehl
Have only done a bit of failure analysis, but I agree, looks like side load fatigue.  I don't see a rotational component in the fracture and it should be more jagged if it were a one time impact/overload scenario.
As per SineWave's comments, I agree and disagree.  From a personal basis, it seems like it should last longer, and this one is probably statistically early as Brucer pointed out.  From the manufacturers point of view, how many of these (similar engines) are on lawn mowers, generators, and personal equipment that won't even see 1k hours over the life of the equipment.  If the failure rate is low enough, any extra $ put into design is a cost without return.
Still sucks.   :(
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
Kbeitz
paul case
Chuck,
I believe his alt is on the opposite side. They changed it somewhere around 96?
PC
pc
Beavertooth
I had a 1988 model LT40HD with a 24hp Onan engine that I changed out to a 38hp Kohler. I talked to Greg at Woodmizer and he told me what to do. All it required was shimming up the new engine 1 inch and putting a different length belt on it. I had to custom fit the guard over the alternator belt and that was all it was to it.
2007 LT70 Remote Station 62hp cat.
Beavertooth
Just remembered that I did not order the new engine from Woodmizer and I had to order it with something different about the crankshaft. I remember it was $200+ for a kit to make it longer or different diameter. Not sure which one. That has been 9 years ago. So since it was farther back than yesterday my memory a little fuzzy on it.  :-\ :-\
DR_Buck
Ordered the 35 HP Kohler from Wood Mizer this morning.  With the install kit it was real pricey.   ::)
Chuck White
Quote from: paul case on June 13, 2017, 09:18:19 AM
Chuck,
PC
I just replaced the 24hp Onan on my mill with a 25hp Kohler two years ago, and the alternator belt pulls in the same direction as the blade drive belt!
Never did make sense to me, even changing the oil filter, I have to be careful not to spill into the alternator!
ladylake
Quote from: DR_Buck on June 13, 2017, 01:11:07 PM
  You'll like that extra power and torque.   About right for a 1 1/4" band.   Steve
