Solar Kiln build
Started by Kbeitz, June 11, 2017, 05:40:30 PM
Kbeitz
Insulation ...
More plywood...
Love machine shop work
and Wood work shop work
And now a saw mill work
GeneWengert-WoodDoc
Maybe you gas usage includes hot water.  I was just talking heating.  Also our house was 2x6.  We paid around $0.50 per therm.  We also had a flat fee of $17 per month, which I did not include.  Of course, there is electric for the fan too.
Ljohnsaw
Quote from: GeneWengert-WoodDoc on June 23, 2017, 04:49:07 PM
Maybe you gas usage includes hot water.  I was just talking heating.  Also our house was 2x6. We paid around $0.05 per therm.  We also had a flat fee of $17 per month, which I did not include.  Of course, there is electric for the fan too.
Now that gives me a sick feeling in my stomach! ::)
I don't have a flat rate portion but my gas rate is $1.31/therm! >:(  My gas bill now (in the summer) is for running two tankless water heaters (so just on actual use) and a gas clothes dryer was 8 therms and is $11 for last month.
GeneWengert-WoodDoc
My error...$0.50 and not 0.05.   A typical house used 700 therms per year for heat or $350 per year for gas heat.
Kbeitz
Question...
Looking at many plans on google I see that some people fan the air in from the bottom and out the top. Other people fan the air in from top and out the bottom. What do you thing is best?  I'm thinking in from the top so it pushes the hot air down through the wood and out the bottom. I'm thinking the other way would waste all the upper heat.
So what do you all think?
scsmith42
Quote from: Kbeitz on June 24, 2017, 11:15:19 AM
Question...
All 4 of my VT Design based solar kilns have vents located directly behind the fans, and a second set of vents located at the bottom of the doors on the discharge side of the stack.
When operating a solar kiln, I tend to adjust the vent settings throughout the drying process.  With slow drying woods such as oak, at the beginning of the cycle I keep the vents closed.  There is enough leakage to allow some air exchanges w/o damaging the lumber by drying too quickly.  On the other hand, if I have a load of 4/4 pine in the kiln, then the vents will be open.
Vent position is also based upon the amount of lumber in the kiln.  If I have a half charge of a medium drying rate wood such as maple or walnut, the vents are closed.  If I have a full charge, then the vents may be cracked open a bit at the beginning of the kiln cycle.
Keeping the vents mostly closed also helps to increase the temperatures inside the kiln.  Drying at a higher RH%, higher temp allows you to dry faster but with less risk of damaging the lumber.  If you keep your vents fully open, the kiln will run at a lower temp, and with lower RH% inside, which will result in a longer drying time and potential damage to slow drying species of green lumber.
Tom's 3638D Baker band mill
GeneWengert-WoodDoc
Fans should blow southward across the collector space and then northward through the pile.  If you go the other way, you will bring in some fresh air at the bottom and it, with recirculated air, will go directly through the pile, and then pick up heat as it goes upward and then some of this freshly heated, drier air will be exhausted before it can do evaporation.
I agree with the comments on how to operate the vents.  In fact, with pine, you may even consider opening the main doors to increase venting, as it is high humidity that will be slowing drying the first day or two.
rjwoelk
I dont see vapour barrier on the inside. Just wondering.
Kbeitz
Quote from: rjwoelk on June 24, 2017, 02:04:11 PM
The vapor barrier is on one side of the insulation.
Do I need more ?
Kbeitz
I'm painting the inside with a 50/50 diesel & tar mix to get my flat black
For the inside walls.  I made a gazebo with this mix and it works great.
Within one or two weeks it's dry to the touch and it really protects the wood.
This should also help with the vapor barrier.  I have stoped working in it until
I finish making myself a metal break so I can alum cap some exposed wood parts on the kiln.
rjwoelk
You just.need a vapour barrier on the inside to keep moisture from migratin in to the insulation. It also seals it up  from air leaks
The same as one would do for a house. But only the warm side gets it.
GeneWengert-WoodDoc
A plastic vapor barrier is better than using the insulation barrier, as the plastic "seals" the walls or floor better...unless someone puts a hole in it.
Unlike a regular kiln where a leak in the vapor barrier means less insulation effectiveness due to wetting and then we can add a little more heat to offset this loss, in a solar kiln we do not have the option for more heat.  So, the solar kiln runs cooler with longer drying time with wet insulation.  With wood walls, decay is also a possibility.
rjwoelk
Not sure i would use tar on the inside. Hot day you brush up against it you will be tarred. Some were i read about a black paint that was good for obsorbing heat.
Kbeitz
Quote from: rjwoelk on June 25, 2017, 04:47:21 PM
Once you mix 50/50 with diesel fuel and it soaks in it does not come off.
It's one of the best wood treatments that I have ever found. After two weeks
it will be dry to the touch.
Kbeitz
I had to stop and build a tool. One tool I did not have was a metal break.
One part of the solar kiln was not getting covered by glass so I went to
the junkyard and found two rolls of gutter alum. I needed a way to make neat
right angle bends so this is what I came up with. The last picture is a small flat
chunk of plate steel that I made my first practice bends on. It works great.
1938farmall
K.  designed & built press brake dies for 33 years - couldn't have done better !
aka oldnorskie
Kbeitz
Quote from: 1938farmall on June 25, 2017, 07:32:50 PM
Thanks...
Kbeitz
Loving the brake...
btulloh
Looks like a handy tool.  You found a good piece of steel. That bevel is the ticket.
HM126
Kbeitz
Quote from: btulloh on June 26, 2017, 08:03:04 PM
I got that last year from the junkyard. I'm thinking that is was part of a brake
or bending machine. I had to drill and tap two holes in it and it was some hard
stuff. It has three rows of magnets resisted in the bottom side.
Kbeitz
I liked it enough to give it a coat of paint...
Kbeitz
Working on the doors...
Kbeitz
I ran short of plywood... Wow... $22.50 a sheet.
Kbeitz
Kbeitz
After seeing the price of large hinges I decided to fabricate my own.
