Solar Kiln build
Started by Kbeitz, June 11, 2017, 05:40:30 PM
Kbeitz
I got a good start on my solar kiln this week.
Love machine shop work
and Wood work shop work
And now a saw mill work
Crossroads
Your making a portable solar kiln? That's cool, great idea. I look forward to watching this project progress
Kbeitz
It wasn't going to be portable  until I started looking at everyone else's build.
I was also having a hard time finding a good place to put it so the kiln would
be getting max sunlight. Now I will be able to adjust it to the sun. Also being
on wheels might help with taxes. I got enough buildings.
tawilson
Plus you can build it at your shop.
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Woodmaster 725
KirkD
Excellent use for an old travel trailer frame and there are a lot of those around. Another plus I see is you could load it at the mill and move it to where you wanted it.
Wood-mizer LT40HD-G24 Year 1989
Kbeitz
Quote from: KirkD on June 12, 2017, 03:54:03 PM
This one was not a travel trailer frame. It started is life as a floor that I had antique water pumps
bolted fast to. I could life the whole floor off my trailer when i needed the trailer for something else.
Them years later it became our DJ floor at out picnic area.
First picture is the pump floor.
Second picture is the DJ floor behind the dance floor. (very hard to see)
This whole floor is made up from scratch.
plowboyswr
Just an ole farm boy takin one day at a time.
Steve
Kbeitz
HOT 95f and I'm tired...
Kbeitz
My projects are wearing me out.
fishfighter
K, I hear you about this DanG heat. Same here too already. :(
YellowHammer
Quote from: Kbeitz on June 13, 2017, 07:22:21 PM
Wait until you start installing the panels, and it starts acting like a hot box.  Then it will really get like an oven.  I built mine when it was snowing, and was working inside in a short sleeve shirt. :D
The higher you build the front knee wall, the taller the rectangular stack of lumber you can load.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
bucknwfl
Watching with anticipation. k, how are you insulating the floor.
Buck
If it was easy everybody would be doing it
Kbeitz
Quote from: bucknwfl on June 15, 2017, 08:24:50 AM
Buck
I used 1-1/2" Styrofoam dense blocks.
Kbeitz
Working solo sure is tough...
Kbeitz
Today's work... I'm now off to the legion.
Kbeitz
The framing is done except for the doors.
One heck of a lot of angles.
Crusarius
That doesn't look very big?
Kbeitz
It's not...But it's big enough for me.
18ft tall
16ft long
6 ft wide.
Big enough for one pallet load of wood. That's my plan.
Stephen1
I like it! I just found a large, inexpensive supply of windows just like yours.
Kbeitz
I got the inside plywood on both angled sides today.
I also got the vents in.
fishfighter
Kbeitz
Quote from: fishfighter on June 21, 2017, 11:53:58 AM
Looking good. ;D
Thanks...
I did not get enough done today to post any new pictures.
I'm putting up the inside plywood across the top inside.
It take so much time working around all the studs that its going slow.
I'm hoping tomorrow I will be done with that part.
Then come the itchy insulation. Uck...
Kbeitz
Just a though today as I was building this kiln...
I was wondering if I could use this thing to help heat my home in the winter. ?
What do you all think ?  Dry wood in the summer and heat my home in the winter...
GeneWengert-WoodDoc
In the winter, due to low sun angle and short daylight. The solar input is low, so you might heat the air from 32 F outside to 60 F during the day, but then you would have to heat the air further before it goes into your home.  Further, your home is perhaps 10x more volume than the kiln.
What does it cost per day to heat your home?  In WI with natural gas we had a bill of $50 for the coldest months for gas.  If the kiln save $5 per month or maybe $30 per year, the cost of piping would probably be much more.
On the other hand, if you have a garage that is unseated, a little solar heat would make the garage feel more comfortable during the day.
Ljohnsaw
Quote from: GeneWengert-WoodDoc on June 21, 2017, 10:44:34 PM
Wow.  I know your winters are a lot colder - my cold months (50 day/32 night) heating (to 65°) is $200-250/month for gas!
