Author Topic: Small seat from offcuts  (Read 670 times)
Offline Ianab
« on: June 11, 2017, 05:31:27 AM »
Needed a little seat for a friend, to put in front of the fire and sit on while lighting it. You know the idea if you have a small wood burner.
So I get some assorted off cuts. Some 2x1 etc. Some nice dry Eucalyptus that's been in the shed for years. It's the sort of wood that's gives eucalyptus a bad name. Warps, checks, gum streaks, honeycomb etc, So it's a matter of sorting out what you can from it. But once you get the good bits, it's probably comparable to Live Oak?
Some planing and it looks better. One piece was warped to heck, but as I only needs shorts I cut it up and planed the shorts.
Then cut the seat profile on the band saw.
And a plan starts to come together.
The legs are glued up laminations, so no need to cut a tenon.
See how it's going to work
Easy to cut the mortise in the centre lamination, and the tenon is exactly the same thickness as the mortise.
Check I have enough slats for the top.
Now glue up the seat rails, with the mortises already in place.
Trial fit
And with the cross stringers in place.
Then the slats can be screwed on from the top.
And a couple of coats of poly to smarten it up.
Over-engineered? Possibly.
Going to fail? Not in this lifetime  :D
Offline Savannahdan
  • Supposed to be retired.
Re: Small seat from offcuts
« Reply #1 on: June 11, 2017, 07:07:00 AM »
Nice and it look just right for the bum.  Thanks for sharing.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill
Offline thecfarm
« Reply #2 on: June 11, 2017, 07:09:35 AM »
Nice. I could almost do something like that.
Offline petefrom bearswamp
  • Location: Finger Lakes region of NY, no more FL in winter
  • made 70-10 and still feelin pretty darned good!
« Reply #3 on: June 11, 2017, 07:34:32 AM »
Very nice.
Great use for some scraps.
In my ignorance I would have burned them to warm my shop
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: June 11, 2017, 07:40:26 AM »
That is a great project.
Offline red
  • we will never forget
« Reply #5 on: June 11, 2017, 08:26:05 AM »
Special two for $300
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline WDH
« Reply #6 on: June 11, 2017, 11:31:47 AM »
Three for $1200  :D
Offline newoodguy78
« Reply #7 on: June 14, 2017, 10:34:52 PM »
Nice clean strong design I like it.
At that bargain price put me in for a few  :) :D :D
