Price per thousand to forward logs ?
Started by trecher2, June 09, 2017, 07:48:39 PM
trecher2
Hello, I'm wondering what a fair price would be per thousand to forward 70,000 bf about 3/4 of a mile. The haul road is already built it has a few steep parts but overall not to bad of a pull. Anyone out there know the going rate ? Thanks
coxy
as much as you can get  :) ;D other than that I have no info for you
wannaergo
Are the logs piled roadside or still on the woods?
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
nativewolf
Would be good to know if you are trying to hire or someone wants to hire you to forward them?
Liking Walnut
trecher2
Logs are skidded out to 3 landings there bucked but not stacked. I'm thinking around 35.00 per thou, would that be in the ballpark ?
RHP Logging
I charge $40/mbf. Plus the move there.  How much do local mills pay for cut and skid? When I set that 40/mbf rate the mills were paying $110-120/mbf for cut/skid their wood a few years ago. I figured a percentage of that. I would probably jack it up a little now because I'm at a steady $130+ per mbf. Don't be afraid to throw some high numbers at em. You can always negotiate.
Buckin in the woods
Frickman
Back before I retired I charged $60/hour for a man and machine, what ever machine was needed. I always charged by the hour, not the board foot. That way things were laid out nice.
BaldBob
Quote from: trecher2 on June 09, 2017, 07:48:39 PM
It would be fairly dependant on the size of the logs (bf/log).
