Clean mold b4 or after
Started by Bigc1989, June 08, 2017, 03:36:12 PM
Bigc1989
I got mold on one stack of my lumber should i clean the mold off and then kiln dry it or kiln dry it and then clean it up? Or it doesnt matter? ??? Thanks in advance!
scsmith42
Quote from: Bigc1989 on June 08, 2017, 03:36:12 PM
Personally I leave it in place.  The kiln will kill the mold spores and the jointer/planer will remove it.
Tom's 3638D Baker band mill
YellowHammer
Let the machines do the work.  Kiln dry it, sterilize, then plane and edge.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Bigc1989
Good enough for me. Sounds good. Thanks!
low_48
I'm not a fan of the idea of filling my shop, my lungs, and dust collector with mold spores. I'd mix up a mildly diluted household bleach mixture and spray it on with a garden sprayer now.
GeneWengert-WoodDoc
Although you might kill the mold now by using a fungicide, the spores that have been created will still be there.  Further, if conditions are ok for future mold growth, the mold can come back unless the fungicide has a long life or time of activity.
In general, adding liquid water (with or without a chemical in the water) to the wood with a species like oak, and even in hard maple, when the wood is partly dried will make any checks a lot worse...the instant swelling of the surface when wetted will pull the checks deeper
Mold and mildew fungi grow only on the surface of wood as there is no food for the fungi inside the wood.  So, it is correct that light planing or even brushing will eliminate the fungi after drying.  Also, it is true that the kiln heat over 133 F will kill them as effectively as a fungicide.  The heat will also kill the spore, so the residue after drying is not an issue, other than dust of any type, including wood dust, can be unpleasant to many people.  In fact the fungi residue is easy to remove after drying with a stiff brush without water.
Bigc1989
Thanks for the options and explanation i appreciate it.
