31-33" circular blade for swingmill or twin blade
Started by CaseyK, June 07, 2017, 04:35:05 PM
CaseyK
Hey Fellas
I am looking to upgrade my twin blade sawmill to cut a 12 inch board and use inserted bits. My existing blades have a 8 hole mounting arrangement typical to a peterson blade i am told. The existing blade spec is 660mm.
4.25mm Plate thickness
8T.
40mmB.
.247 kerf
4-12mm.PH-104mmBC. 4-12mm.PH-114mm.BC.40DG.HK.LH.CS.
I was hoping to use the same drive shaft and arbor if possible. I remember someone on here stating that the rim speed needs to stay around 10k ft/min so i will adjust the sheaves to accomplish that but im unsure how many teeth to spec and the gullet area so i was hoping to find someone that has the spec for there blade that fits the size range with inserted tooth and i can get one built with my mounting holes spec.
Any help would be appreciated greatly.
Casey Kennedy
Home built automated twin blade
dgdrls
Hi CaseyK,
First place to go is FF sponsor Menominee Saw  http://www.menomineesaw.com/
They will steer you right,
D
CaseyK
