Thank You Timberking
Started by woodman58, June 02, 2017, 07:18:03 AM
woodman58
The other day I was doing some adjustments to the chain that raises and lowers the head. Never touch this chain! Needless to say I broke the chain. I should have adjusted the guide rollers, not the chain. I have a mobil  job set for Saturday so, I called Timberking and talked to them about it. They said bring the mill to them on Friday and they could fix it. I decided to go to Kansas City Thursday and get a motel so they would have plenty on time to fix it. I showed up at 2 P.M. and they said they could go ahead and fix it right then. They got done at 4:30 and I was able to save the money for a motel (and buy a spare tire for the mill) and drive home in the same day. Thanks Once to all the Timberking staff for fixing my mill (at no charge) and keeping me entertained for 2 and 1/2 hours.
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
LeeB
woodman58
No, I did not visit the caverns. I have been to Meramec Caverns and several others. To me they all look the same. I spent my time with the Matt (my sales man) and talked to the Woodmaster sales staff about how to set up my Woodmaster to make molding.
Timberking 2200
Kbeitz
Tell use more about this molding attachment...
Love machine shop work
and Wood work shop work
And now a saw mill work
LeeB
Quote from: woodman58 on June 02, 2017, 07:47:41 AM
:D :D I was referring to the caverns where they have their fabrication plant at. Or at least that's where it used to be. May not be there anymore.
woodman58
Kbeitz, The woodmaster is a planer, sander, gang rip saw, and molder. The parts can be changed out to do any of the function. There are many knife profiles to chose from. You can add an attachment with two routers to make a three sided molder. You can check it out at the Woodmaster logo on this page.
LeeB, I did not know that is where they make them.
Timberking 2200
DbltreeBelgians
Quote from: woodman58 on June 02, 2017, 12:22:56 PM
Woodman58,
I have an older Foley-Belsaw 5hp 12" moulder-planer and was wondering if the Woodmaster has any interchangeability with my Foley-Belsaw. If I recall correctly they were Belsaw back in the day. Any thoughts?
Thanks,
Brent
LeeB
They used to handle foley belsaw parts. Click on the timberking link on the left of the page.
Will_Johnson
Thanks for the kind words.
Woodmaster carries feed rollers that will fit the old Belsaw machines, but otherwise there are no common parts. Give them a call at 1-800-821-6651 and they can fix you up!
DbltreeBelgians
Quote from: Will_Johnson on June 05, 2017, 02:17:53 PM
Thanks Will, I'll give them a shout and see what we can come up with.
Brent
