cost of an older lt 40?
Started by Paintman, May 31, 2017, 09:38:27 AM
Paintman
Hi guys. Im obviously new here. Im from central Indiana. Before my actual question ill give you a little back story. Im 31 and i do automotive collision repair. My dad ran a fairly large sawmill for about 35 years. He is now 61 and hasn't been in the business for about 10 years and i know he misses it. i have become interested in owning a small sawmill. As my interest has grown i found this site.
Ive done quite a bit of research and i have gotten a lead a wood-mizer lt40. its a late 80's model and it is manual. The up side is it has less than 100 hrs. and looks like new. So my question is what should i expect to pay for something like this? I would Involve my dad but im trying to keep it a surprise. So any help would be awesome. Thanks!!!
2017 woodmizer lt40 super with lube mizer and debarker.
fishpharmer
Paintman, welcome to FF.  You cannot go wrong with a woodmizer mill.  Give Woodmizer a call at 1 (800) 553-0182 and ask them to give you an "Orange Book" value for the mill.  If you can get the serial number they can tell you how it came from the factory.  Otherwise, search sawmill exchange, craigslist and the for sale section (here) to get an idea of the market price.  Going only by the year I am guessing less than $10,000.  Purely a guess, good luck!
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Deese
Welcome to the forum Paintman, and good luck!
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Sixacresand
Welcome the Forum.  Good luck with your mill purchase and it's great that you include your Dad.
Paintman
Thank you guys. I'm one of very few people in my family that hasn't taken the sawmill route in life. Most of my family are from Monticello Kentucky and work in or own big mills. And I couldn't think of a better person to learn from than my dad. I've also looked a woodland 130 but I'd really like to stay Mobil and it seems like wood-mizer may have more Add ons available.
Darrel
Welcome, glad to have you aboard. I paid $10,000 fo my 1992 LT40 hydraulic.
1992 LT40HD
POSTON WIDEHEAD
............and just for fun, when you call Woodmizer ask them if they have any upgrades that will fit this mill
to where its not so manual.  ;D
esteadle
+1 on sawmillexchange.com for comparables.
There's an LT40 there w/ about 200 hours for $17k.
LT30 as well.
WoodMizer is excellent so give them a call.
Chuck White
Welcome to the Forestry Forum, Paintman!
50 Acre Jim
I'm new to this forum as well.  But Welcome!
Go to work?  Probably Knott.  Because I cant.
dgdrls
Paintman,  welcome,
good advise already posted, WM makes a dandy mill and are a great company to work with.
FWIW as Fishpharmer noted I would be looking for <$10k on the price for a manual 40
D
Crossroads
I have an 85 lt 30 that I paid $6750 for a couple years ago. It came with 30 blade a pv and the engine had been upgraded to an 18 hp. Since then I've axed a hydraulic log turner/clamp and powered the backstops. I've also made several other mods that make it more user friendly and another 30 blades. If I was to put it up for sale today I would start at 12k with some wiggle room. Good luck!
PS if I was going to buy another mill tomorrow, it wouldn't be manual
paul case
Quote from: Crossroads on June 03, 2017, 12:13:29 AM
Same here.
PC
pc
Paintman
I've been told this. And Ive also been looking for a hydraulic I can afford. If needed can I add hydraulics to this lt40 later?
fishpharmer
Quote from: Paintman on June 03, 2017, 09:05:20 AM
The short answer is "no," in my opinion.  The long answer is "yes" anything is possible, it will take considerable expense and or fabrication skills, again thats my opinion.  If you or a buddy has the skills and tools to fabricate its very doable if you don't have to pay someone.
pineywoods
Paintman, you indeed can add hydraulics to an older lt40 BUT, not really practical to add the factory hydraulics. Use the forum search function to search for "home made hydraulics" Pics. dimensions, descriptions for turner,  2 plane clamp, toe roller and backstops. No welding on the mill, everything bolts on. The original is on my 95 lt40 in daily use. Easily adapted to other mills..cheap
Darrel
Another option instead of adding hydraulics later is selling the manuel mill and buying a hydraulic mill after the manuel mill makes you a little money.  You should be able to sell the manuel for what you pay for it.
1992 LT40HD
D6c
I have an '87 LT40 manual that my dad bought new....at the time I think is was around $10,000.  Not sure what it would be worth today but with price increases and added features on the new mills I wouldn't be surprised that one like it would come close to bringing the original price.
You asked about adding hydraulics to an older mill....I decided to do it because a manual mill can get pretty slow and physical if you saw very much.   Adding hyd. can be done but it's a job. I'm part way through modifying my LT40 and to give you some idea what's involved, here's my progress so far.... https://forestryforum.com/board/index.php/topic,96274.0.html
I still have to build toe boards and linkage to power the side stops.  I've ordered a hydraulic pump and other parts to begin putting together the power unit.
It's not inexpensive but I had the advantage of not having to buy the mill first since it came from my dad's estate.
Just as another thread I posted,depends. I only saw for myself,manual mill suits me fine. I do have a tractor to get them on the log brough. I cut the tree down,saw the logs up and build. When that tree is done,I cut another tree and start all over. Yes,hyd would be nice,but I would rather spend the money on other equipment I need. My mill has sat for more than year,waiting for me to start building.
Deese
I've never pushed the mill until yesterday. I was sawing syp 1x4's yesterday evening for a customer. New blade. Made a cant, cut 4" thick slabs being sure not to split the pith, flipped them 90°, programmed to drop 1 1/8" each cut and hammered down. Each pass making 3 1x4's. Without the command control, I would have been jogging to keep up.  I don't know how I ever survived without hydraulics.
Cooks AE4P Edger
Paintman
I talked to wm today. They told me the value is around 7500-8000. And they also said hydraulics can not be added. So I think this is a no go. I will be watching around and plan to have some bought soon.
Kbeitz
Quote from: Paintman on June 05, 2017, 03:33:34 PM
I love it when someone say it can't be done...
Love machine shop work
and Wood work shop work
And now a saw mill work
DbltreeBelgians
Paintman,
I'll be at the auction looking to get a metal lathe. The LT40 is to be the first item to sell. I'll let ya know how things go. I think in the long run you'll be happier if you can find a hydraulic mill. My mill was all manual when I purchased it and I added hydraulics and love it. It was a lot of work but I wouldn't go back. I still don't have power feed or power raise and lower but that's in the works.
Keep watching the for sale board and also the Sawmill Exchange. I'm sure you'll find the right mill for you and your dad.
Good luck,
Brent
Darrel
I found my LT40 on Craigslist
1992 LT40HD
DbltreeBelgians
Hey paintman I'm glad to hear you pulled the trigger on a new hyd mill.
I just got home from the auction with a woodmiser single tooth setter for $30.00, a woodmiser ADS-30 sharpener for $20.00 and a big set of logging tongs and 2 single hooks like Magicman uses to roll his logs. Also to let you know the old LT-40 sold for $8700.00 along with 3 boxes of blades, an extra drum switch and a bunch of misc. stuff.
They ran the mill and it sounded ok but I think you'll be much happier with your new one.
Brent
