Water pump
Started by Crossroads, May 25, 2017, 03:33:46 PM
Crossroads
I got tired of the blade lube tube plugging up and not giving a constant flow of water so, I ordered a cheap 12v pump online that has 35psi and a built in switch. I'll eventually put a proximity switch on it so it's only powered when the clutch is engaged. For now though I should have a nice constant trickle coming out of the needle valve.
You need a filter/screen on the intake side of the pump.
Crossroads
There's a screen on the outlet of the jug, will that be enough?
I use one of these.  You can see what is inside plus the "sight glass" unscrews for easy cleaning and Winterizing.
Crossroads
Thanks magicman, I dropped one in the shopping cart.
