Help drawing timber frame
Started by Tyler.schmick, May 25, 2017, 11:01:42 AM
Tyler.schmick
I would like to know if there is a engineer or architect that could look at my timber frame and make suggestions. Also, what is the going rate to have someone draw a truss design?
Thanks!
Ljohnsaw
Do you need to submit to the county?  IF so, you need an engineer licensed in your state.  I used Ben from Fire Tower Engineered Timber out of Rhode Island.  He is licensed for California and IIRC, Rhode Island and Massachusetts - maybe a few other states.  Cost depend on the work.  I maintained the drawings, Ben over saw the work (highest wage) with a junior engineer doing most of the work.  I spent a few thousand on getting the plans signed off.  Then the county wanted some changes/clarifications.
VictorH
Hi Tyler!  Welcome to the forum.  What part of Nebraska are you in.  I'm in the Southeast corner.  Forum member Jim Rogers does design work.  He has designed 3 structures for me and has an engineer that must be licensed in NE.
Victor
Tyler.schmick
I am in McCook Nebraska!(southwest)... I don't need to submit anything because my county doesn't require, I just don't want to order timbers until I know my plan is right. I don't need anyone to oversee etc, just to look at the plan.
Thanks!
Tyler
1234wood
I need help with bents spaceing for sawmill building I need 16 ft opening for logs to come thru to mill I'm useing white pine 10x10 or 12x12 for bents  24x36 building timber raffters any one can help yes I read and understand and agree
Tsmall07
What software did you use for that design?
MbfVA
 This thread is a couple months old, but I believe that drawing was done in sketchup, and it looks amazingly similar to a design I saw in the sketchup 3D warehouse.  If you were not familiar with it, sketchup is a great drawing program available for free use and also in a pro version, about $700.
www.ordinary.com (really)
