Wood Mizer Electrical H bridge wiring.
Started by MartyParsons, May 23, 2017, 08:03:52 PM
MartyParsons
Hello,
   Just wanted to take a picture of things that could make your life more difficult. Not sure if I even need to write much about these pictures. They kind of tell their own story.
The first two are before and the last one is how it should look.
The two yellow wires that are sticking out of the right plug can be plugged in and you would have control of power feed speed in reverse. Super or 70 walk mills sometimes require this to be plugged in. This mill has about 3700 hours on it.
Hope this helps.
Marty
LeeB
Plugged in where Marty and what year models is that possible on?
MartyParsons
Hello,
This would be for Accuset 2 and later mills.
M
LeeB
Ah well, that would count me out. Thanks anyway.
