WM brg support install
Started by petefrom bearswamp, May 16, 2017, 06:24:15 AM
petefrom bearswamp
Going to install the brg support this Friday as i have help coming.
Anything i should be aware of as regards possible problems?
I have a fair amount of mechanical skill but my fingers and muscles dont work as well as they once did.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Chuck White
Ga Mtn Man
red
I thought it was British Racing Green ? ? ?
petefrom bearswamp
Guess I should have been more specific
WM calls it support assembly Cat bearing LT40/50 D51
Kubota 900 RTV
moosehunter
Wish I could come help you and learn how to do mine at the same time.
"And the days that I keep my gratitude
Higher than my expectations
Well, I have really good days".    Ray Wylie Hubbard
MartyParsons
Hello,
   We started a head gasket and crank support kit on a LT50 with the 51 hp Cat today.
Metric Allen wrench for the stub shaft. You will need to heat the cap screws and they will come out easy. Propane torch may work.
You may need to shim the alternator pulley with a washer to help with alternator belt alignment. After you install the new stub shaft.
This engine already had a belt issue with the outside of the belt missing one strand. I have also shimmed the tensioner if it hits the alternator pully fan.  The Drive belt was also not one but three so it will be replaced also.
Remove the drive belt tension! before installing the drive belt. I like to make sure everything is aligned on the drive belt then engage the drive belt then adjust to the proper spec.
This taper lock on the drive pulley was very tight tight. Three 1/4" 20 bolts. Remove them and then put them back into the threaded holes. Tighten as much as you dare, then take a block of wood and drive the pulley away from the lock. Tighten the bolts again then repeat. I used a puller once it came loose to remove the lock. Lock tite back on the new cap screws for the stub shaft.
Hope this helps.
Sorry I thought I had pictures before . I will do this the next time.
Marty
Nomad
     Pete, I'm glad you posted this.  I'm about ready to put mine in too and I'll be watching this closely.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Chuck White
That's kind of what I thought it might be Pete, but just wasn't sure!   ;)
