Author Topic: Substitute tool to burnish the edge of a scraper?  (Read 763 times)
Offline Delawhere Jack
  • I ought to know better.....
« on: May 09, 2017, 08:58:38 AM »
I picked up a hand scraper to finish a top I'm working on. WoodCraft had burnishing tools, but they started at $40  :o I've tried a number of things around the shop to use to burnish the edge, but none seems to work. Any suggestions for what might work for a cheapskate like me?
black walnut, cherry, SYP, southern magnolia, poplar, hemlock, osage orange, red oak, white oak, chestnut oak, black locust, english walnut, ERC, WP, hickory, ash, black birch, beech, honey locust, apple, white cedar, black oak, basswood(?), sassafras and a "Christmas tree" full of iron
Offline LaneC
  • P.M. Lodge # 111
Re: Substitute tool to burnish the edge of a scraper?
« Reply #1 on: May 09, 2017, 09:56:38 AM »
   A long screwdriver. usually a phillips because they are round. Most regular screwdrivers have flat sides on them. You just have to press hard when using the Phillips screwdriver.
Man makes plans and God smiles
« Reply #2 on: May 09, 2017, 05:53:44 PM »
I'll try pressing harder... :D I was thinking of the tang of a large round file, but I'd need to grind the surface smooth.
Offline Just Me
« Reply #3 on: May 09, 2017, 06:27:06 PM »
I use a fuel pump pushrod out of a small block chevy. Non chrome plated stuff works better.
Offline ljohnsaw
« Reply #4 on: May 09, 2017, 06:41:46 PM »
I've found that file tangs are actually soft metal (and square).  The smaller the diameter, the more pressure / sq-in will be applied for your effort.  So, how about a nail set or even an ice pick.  Both of those are pretty hard.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Online muggs
    • Hardins industries
« Reply #5 on: May 09, 2017, 07:32:28 PM »
I have a metal lathe, so I use a tool bit which is High speed steel.   Muggs
Offline ljohnsaw
« Reply #6 on: May 09, 2017, 07:45:30 PM »
I do to but not many have that to use.  However, just about everyone has drill bits!  Use the shank on a drill bit to do the burnishing - that should work great.  Just make sure they are good, HSS bits, not some cheap HF ones ;)
John Sawicky
« Reply #7 on: May 09, 2017, 10:29:27 PM »
Thanks all. Some good suggestions. I'll report back with what works. Already tried several of these ideas. This scraper seems to be awfully hard though. HSS drill shank will barely touch it.
Offline 21incher
« Reply #8 on: May 10, 2017, 07:26:21 AM »
Be sure to file it square first. The previous burnishing may have work hardened it. I use a old Stanley nail set.  I purchased one of the triangular burnisher years ago and never had any luck using it.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Jemclimber
« Reply #9 on: May 10, 2017, 11:26:16 AM »
The sides of a depth gauge (raker) file is what I use. If you file your chainsaw teeth you should have one. It's also what I use to square up the top. A depth gauge file has no "teeth" on the sides to avoid dulling the chain and is as hard as the flat cutting part.
Put the scraper in a vice, square it up and turn the file to quickly burnish it.
lt15
Offline Larry
« Reply #10 on: May 10, 2017, 12:49:13 PM »
An old steel hone, like used to sharpen knives, works better than the screwdriver trick.
Larry
Nine out of ten trees recommend wood for your building project.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #11 on: May 11, 2017, 04:55:53 PM »
Somewhere I saw that an engine valve stem works great for this.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
