mowing the lawn.
Started by thecfarm, May 07, 2017, 08:19:49 AM
21incher
Quote from: thecfarm on May 08, 2017, 09:01:42 PM
21incher,you need some rocks to mow around.
I do have 3  ;D the roller pushes the rest back down into the mud.
Chuck White
Well, no rain today, but the grass was still a little on the "wet" side!
I just got sick of looking at it and just started mowing!  I ran the throttle a little higher than I normally do, to aid in blowing the grass out of the deck!
Looks pretty good and it is finally mowed!
 3 rocks.  ::)  ???
This is behind the house.
Some rocks are 2 feet above the ground.
This is below the house. I am digging a few out.
Just for size. That is a yard stick.I think that is the rock on the right in the above picture.
Can I borrow that roller? :D
Better left for the trees.  :D
21incher
thecfarm I think you are going to need a much bigger roller then the one that I use.  :o :o :o Around here they sell rocks that large for big bucks.   :)
Just like money in the bank.  :D
Can't really tell by the picture,I bet there is over 100 rocks in this pile.
As my Father use to say,I could not run fast enough to give them away.
Not much of a market for rocks that size here. Send them my way,I'll give you 10%.  ;D
21incher
When I see a pile of rocks like that all I can think of are SNAKES running-doggy running-doggy running-doggy running-doggy running-doggy
coxy
hey hey don't be tellen the out of staters about our rock markets   :D :D :D  and ya the bigger the rock piles the bigger the snakes
Nope,never seen a snake in The Rock Pile. I saw many a wood chunks in there. That pile is getting smaller by the day,one rock a day,goes up into the bog.
All  the grass at the Cabin got mowed during the past couple of days and the only mishap was when some debris wrapped around the blade spindle.
This was nothing that some careful knife work and then a trip to the Health Dept. to get a Tetanus shot couldn't/didn't take care of.  Actually they now call it a Tdap vaccination.  Oh yes, and the bandage.   :-X
sandhills
Lynn, I really enjoy MOST of your pictures but man, you need to start wearing armor or something  ;)
Think that it looks bad, you shoulda felt it.   :o
coxy
you shur do keep the docs well paid  :D :D
21incher
Quote from: Magicman on May 12, 2017, 12:47:53 PM
The pain is there to remind us not to do it again. Hope you heal quickly. Reminds me that I have not had one of those shots in about 5 years. :)
Kbeitz
My wife is from Dominican Republic and they don't mow grass down there.
I don't think I could ever get her to mow the grass. I make it a habit to watch
for tractors and mowers every time I go to the DR. I have only seen one push
mower and it was on a back of a motorcycle.
Love machine shop work
and Wood work shop work
And now a saw mill work
WV Sawmiller
   When I first moved to WV I seriously considered posting a sign "Anyone caught stealing the rocks or multi-flora roses will be prosecuted to the full extent of the law". I was hoping people would think they were valuable and might come take them.
Ox
It would have worked around here.
sandhills
Can I add muskthisle, erc seedlings, and leafy spurge to that sign?
coxy
do they make steel spindle housing for the mower decks these potmetal ones suck every time I hit something they brake the last time 2 days ago it was a soft ball put the blade through the deck shredded the belt bent the blade  I think I'm going to try to make something different for it they bang me 60 $ a pop for them I think they are making a 55$ profit cause they are junk
LeeB
check on amazon. I bought 3 replacement spindles and blades for somewhere around $125.
Ox
Seems like I remember Oregon selling upgraded replacement spindles...
coxy
Quote from: Ox on May 22, 2017, 02:32:10 PM
they are the ones I got but still pot metal  I think that's what its called regardless its junk  ;D
Ox
Nuts.  I'm out of suggestions then...
sawguy21
The blade spindles are designed to be sacrificed, they prevent major breakage or injury and are a good money maker. The machine is a grass cutter, not a brush hog or scarifier. Quit trying to move rocks or stumps.
LeeB
You mean I can't use it to mulch the sticks and debris in the yard? Why the heck did they sell me mulching blades?
