What kind of log is this??
Started by Brad_bb, May 06, 2017, 08:53:42 AM
Brad_bb
I milled a log yesterday that I cannot identify.   I'm in IL.  I've never milled this before.  Bark reminds me of white pine, but it's not a pine for sure.  Seems like a hardwood. Not much distinction between rings.  No pores.  Any ideas?  Had an odd smell, a little pungent like Red Elm(which I was milling he same day) but not the same as elm.
qbilder
God bless our troops
Brad_bb
Definitely not.  I've milled Cotton wood. The grain of cottonwood is more distinctive and will give you that Cathedral grain look whereas this does not.  It looks so uniform it's difficult to see where one years growth ring ends and the next one starts.  Cottonwood has distinct lines between each ring.  Cottonwood is not this light either.  Also to note, there's no metal in this log.  Those dark spots are not metal.  Some look like small bark inclusions.  Not sure what they are.
Hewer of Wood
1997 Timber Harvester 1967 Pettibone Super 8 and too much sawdust. Joshua 9:21
Brad_bb
Good guess. I looked up but pic of wood doesn't quite match.
http://www.wood-database.com/water-tupelo/
In the tupelo description it also said Tupelo-gum.  That made me think maybe it's another gum like sweetgum. So I looked that one up and it sure looks like it.  I think it's sweet gum.
http://www.wood-database.com/sweetgum/
pineywoods
Sweetgum. Likely will warp and twist in more ways than you can think of  ;D
ChugiakTinkerer
We get hybrids of cottonwood-poplar in my region.  Not saying it's either of those, but you could be getting some hybridization making it more confounding.
Woodland Mills HM130
Ron Wenrich
Yard tree or a woods tree?  You're a bit out of the sweet gum range for it to be a woods tree.
It looks a bit more like black gum - nyssa sylvatica.
Brad_bb
Pineywoods.  I left it 6 inches thick cutting off two sides only.  I'll let it stabilize in the barn for a year and then see what it looks like and see if I'll use it anywhere.
Brad_bb
Quote from: Ron Wenrich on May 06, 2017, 10:13:25 AM
Yes, likely a yard tree.  My main log supplier is a firewood operation that has relationships with tree services.  He separates out the nicest logs for me to mill instead of making firewood out of them.  i've got him trained for the curved and wonky pieces i look for timberframing.   I think it is sweet gum.  He gave me a piece before that was only 4ft long curved that he told me was sweet gum.  It was just so small that I didn't get a good feel for identifying it.
The tree serviced he deals with cut in town and rural.  I've had some nails in Ash and Walnut, but not so much that it bothered me.  I'm surprised how few nails/metal I come across in the logs.  If there are some nails in Walnut logs, I care alot less because usually Walnut is worth a band. Once i hit them, I yank them and move on.
nativewolf
Pictures of end grain are always really helpful when ID'ing wood.  Do you have any?  Dampen the wood a bit so the cell structures pop out a bit more.
Liking Walnut
paul case
Looks like one of the 3 types of Hickory we have around here.
PC
pc
SineWave
Basswood/linden?
One way to tell if it's sweetgum is to try to split it. Due to all the interlocking grain, a splitting maul will just bounce off of it – as if the log was made of rubber – until you're blue in the face. If you try to split it with a hydraulic log splitter, chances are it will just turn the log into a wad of ropy fibers...more malleable, but still not divided into multiple pieces.
If you're getting it from a firewood supplier, this is probably why he wants nothing to do with the stuff...
kelLOGg
Hickory is what it looks like to me.
Bob
TKehl
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
SineWave
Pecan or another type of hickory was also what came to my mind first...except the pecan I've seen didn't have that gray cast to it...otherwise, it looked similar...
We had a huge pecan in the yard get killed by lightning, which was a real bummer because the nuts (mahan pecan variety, also called "papershell") were large, reliable, delicious, and could be cracked open without a nut cracker (just take two in hand and crush them together)...thankfully, that cultivar is true to form and it had many offspring...
Chuck White
Not sure by any means, but I'm guessing Soft Maple!
buzywoodliff
I was thinking some kind of maple as well..??
LAZERDAN
If n you know it's not cotton wood,  that bark and the wide grain and the holes make it look like willow,  It's hard to lick that wood from a pic ............  Lazerdan
kelLOGg
Wow! We are all over the map. Can you tell us more about the log? e.g., density, weight?
Bob
carykong
I vote gum tree,too.  I have seen the imbedded bark characteristics in gum that I have sawed. Young limbs long gone and overgrown by the latest growth rings.  Color looks the same.
etroup10
NHLA 187th class, lumber inspector. EZ Boardwalk 40 with homemade hydraulics; Gafner Hydraloader; custom built edger, Massey Ferguson 50E, American Sawmill 20" Pony Planer; Husqvarna 55 Rancher
fishfighter
Quote from: Brad_bb on May 06, 2017, 09:28:16 AM
I don't think it is sweet gum. Bark is way to heavy.
paul case
That smell, does it kind of remind you of a horse stable?
The bark looks hickory to me and the dark in the outter wood happens to some hickory when it has ben cut down and not milled for a bit. I bet the guy who had that in his yard was happy to see it go. Hickory trees that size make jillions of nuts.
PC
pc
Don P
The first pic, the wood does look like mockernut hickory to me complete with the greying from sitting too long. The bark doesn't to me.  ???
