fair trade
Started by chet, April 23, 2017, 10:03:57 AM
chet
I think I did OK on this one.   :)  One day of sawing some red oak, for a '76 Chev Custom Deluxe.
Everything works, even the radio and CB. ;D
sandsawmill14
good looking old truck smiley_thumbsup i would have took that trade to :)
red
C70 maybe airbrakes 366 5 spd 2 spd
nice truck
sawguy21
Looks pretty decent for a 40 year old dump truck, they don't tend to wear the years well.
That is Yooper Luck  :D :D.
chet
Quote from: WDH on April 23, 2017, 11:25:39 AM
Luck wood'a meant it came with a full tank of gas.   smiley_smug01
sawguy21
 :D You don't want much.
Darrel
Nice looking truck and the rubber even looks pretty good. And a truck from the 70's wouldn't be a truck without a working CB.
1992 LT40HD
Kbeitz
Looks like it needs a CDL.
Love machine shop work
and Wood work shop work
And now a saw mill work
sandsawmill14
Quote from: Chet on April 23, 2017, 02:42:00 PM
as much gas as they burn 1 tank still wouldnt have got very far ;D :D
Quote from: Kbeitz on April 23, 2017, 05:02:55 PM
no cdl needed down here but idont know  ??? when you get that far north its a different world ;D :D :D :D
WLC
Mighty fine looking truck.  My luck isn't ever that good.  I could use a truck that size from time to time and would be tickled pink to make the trade you did.
As far as a CDL, I doubt it.  GVW has to be over 26K pounds for a single vehicle unless something has changed since I gave mine up.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
scsmith42
Tom's 3638D Baker band mill
WV Sawmiller
Chet,
   IMHO you done good! The customer did too if he was happy with the trade. That is my definition of a good trade - when both parties are happy with the end results. Well done. I hope you get many years of safe and happy years service out of that truck.
red
Since the cab is so clean maybe a fire truck that someone put a dump body on. That front bumper and grill looks brand new.  I call those wheels tractor trailer wheels.
chet
I have the original bill of sale, it was bought as a dump truck. The GVW is 25200# but it doesn't matter as I have a Class A CDL anyway.
YellowHammer
That's sweet.  You must be living right.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Nice. Wanna race? I get a head start though as mine is 30 years older.
chet
I 'spose I gotta remove two spark plugs and not use da high side of da split either.  ;D
fat olde elf
Good for you ,Chet !!!  See you at the Pig Roast !!
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
sawguy21
 :D :D Chet, I almost spit coffee on the screen, that is funny. Keep the wheels properly torqued, they have a bad habit of working loose. I believe they are no longer legal on a steering axle here.
barbender
I've not seen a Dayton wheel work loose. I've been around them a fair bit and never knew of an issue. I can see if someone installed one wrong, I've seen them going down the road wobbling 3" side to side :o
sandsawmill14
Quote from: barbender on April 24, 2017, 07:19:35 PM
x2  and if you have to take them of to fix a flat drive it just a few miles and re torque  ;) them suckers will cut both valve stems smooth off at the rim and they are not tight when you hit the brakes >:( dot ask me how i know :-[ ;D
