BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Testing Homemade Bandsaw Mill  (Read 1044 times)
Offline harmons_ranch
« on: April 20, 2017, 07:10:34 PM »
Below are some pictures of the first log cut on my homemade bandsaw mill.  It's still in the testing phase, but following a few tweaks it should produce good dimension lumber.
The blade runs on temporary spare tires and driveline components from a junked Chevy Cavalier and is powered by a 10 HP Tecumseh engine salvaged from an old snowblower.  I've yet to finish weld some components as I wanted to be sure that it would work as expected.  It appears to cut straight and square, with the exception of going too fast through a knot that caused a minor dip. I'll post pics of the mill when guards are installed and other minor items are completed.
I'm a novice when it comes to mills and sawing, but many months of research conducted prior to countless fabrication hours seem to have paid off.  :) (demonstration/explanation video to follow)
Has anyone had any issues with blade set when using tires?
Offline fishfighter
Re: Testing Homemade Bandsaw Mill
« Reply #1 on: April 20, 2017, 07:21:50 PM »
Looks like a good start. And welcome aboard.
Online thecfarm
« Reply #2 on: April 20, 2017, 07:26:14 PM »
harmons_ranch,welcome to the forum.
What's the plan for the lumber?
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #3 on: April 20, 2017, 07:46:14 PM »
Some have trouble with tires taking the set out of the blade and others don't.  I didn't.  But I think it's because it was trailer tires I was using and they have a nice radius.  Car tires like you're using generally don't have.  You might have to grind/cut a strip of rubber off where the teeth ride when under tension.
Looks like a good start with the cant you ended up with...
« Reply #4 on: April 21, 2017, 07:36:02 AM »
I have land at the head of the pond shown in the picture; that is where I plan on setting up the mill and hopefully building a small cabin.
Online thecfarm
« Reply #5 on: April 21, 2017, 09:15:42 PM »
I do hope you take us along for the build.
Offline Slingshot
« Reply #6 on: April 21, 2017, 09:49:33 PM »
  For the build??????????????????...Give me a fishing pole!!!!!!!!!!! 8)
_______________________________
Online thecfarm
« Reply #7 on: April 22, 2017, 05:37:51 AM »
I meant pictures. ;D
Offline bandmiller2
« Reply #8 on: April 22, 2017, 07:30:36 AM »
Welcome Harmon, anyone can go out and buy a mill and be successful, to design and build your own is another thing. Run it and don't be afraid to modify and change things to suite yourself, you are the OEM and write the rules. Any plans to sharpen your own bands.?? Frank C.
« Reply #9 on: April 22, 2017, 08:12:23 AM »
I certainly will post as many pictures as I can along the way.  This year will likely be cutting logs and sawing lumber with next year being being the beginning of construction (fingers crossed).
« Reply #10 on: April 22, 2017, 08:15:42 AM »
Plenty of trout in that pond...easy to catch and quite tasty.  I grew up near there and spent many evenings after school catching them.  I often go there now and cook up the catch over an open fire. :)
[/quote]
« Reply #11 on: April 22, 2017, 08:33:39 AM »
Thanks, Frank.  I spent close to a year reading every scrap of information I could find on this forum and anywhere else before I began building the mill.  It's been about eight months since I started with what I'll call cosmetics remaining.  I've also spent time researching sharpening methods and I'll certainly give it a try.
Offline Qweaver
  • The cabin is done and we love it
« Reply #12 on: April 23, 2017, 11:24:02 AM »
Congrats!  Building your own mill is quite an undertaking.  Good luck with the sawing and building.
