stump grinder vs auger vs planer
Started by quilbilly, April 20, 2017, 01:47:01 PM
quilbilly
I am looking at getting a stump grinding attachment for the mini. It's a Kubota 35. Wondering whether I should get a stump grinder or stump auger. I saw an auger looking deal from fecon that looked pretty neat. Most stumps would be in the 15 inch plus range, up to 4foot cedar stumps
a man is strongest on his knees
DDW_OR
I have a bobcat 331 = about 8,000 pounds, similar to yours.
i use a frost ripper tooth.
http://www.bobcat.com/attachments/ripper/features
quilbilly
We have legit four foot stumps, some a bit bigger. Will a ripper tooth really bust through roots that big? I'm also not sure we want to leave giant craters as much as grind them down.
DDW_OR
looked at a video of the auger. it is slow. and what do you do if the stump is bigger than the auger?
http://www.equipmentworld.com/fecons-stumpex-attachment-removes-most-stumps-in-just-90-seconds-makes-debris-cleanup-a-snap-video/
I use the ripper on stumps 24 inch and less.
if i was you i would rent a grinder and see how it works, then if it does what you want then buy one.
quilbilly
That post says they did a 5ft oak in 25 min. A 5 ft second growth cedar should take less I would think. I think the ripper tooth would be nice though time wise.
TreesLogan
Quote from: DDW_OR on April 22, 2017, 03:41:42 PM
I agree see if you can rent one and then make a purchase based on how it works even if you lose some time in driving to pick it up from another city it beats dealing with buyers remorse later.
When you wake up and realize you sarificed your passion for a dollar that never came. At least I am awake now. http://www.treeserviceloganut.com
DDW_OR
....I use the ripper on stumps 24 inch and less.........
i guess i should clarify why i use the ripper on stumps.
i am clearing land for a pasture that i will disk, then plant.
